Amana timer bad?
7 replies to this topic
#1 cllvt
cllvt
  • 5 posts
Posted 10 February 2006 - 03:41 AM
OK, 1998 Amana LWA50AW washer - the cycle knob select skirt was not engaging.  I removed the knob, skirt, timer, saw nothing obviously wrong, so reassembled everything.  Seemed to work, I assumed the knob has just been loose, and I was OK now.  :P
As we started the washer, and used it, it became clear that the "dot" on the skirt was not indicating the correct corrosponding point on the panel.  :( In other words, you might select a permanant press cycle, and while it did start/run, the cycle went much longer than the cycle should run, and when it finished it was halfway into the next indicated (delicate) cycle.   I assumed I had the skirt installed incorrectly, but while it WILL go on the shaft two ways (180 degrees opposed) it looks like it SHOULD only go on one way: on the shaft there is a flat, and opposite that a spline sort of protuberance on the skirt/ on skirt a flat and channel that looks like it should recieve the spline.   However, when installed "properly", the cycles do not appear to line-up, and if installed 180 degrees off, that does not appear to line up with appropraiet cycle start points either.
Is there a way to reset the timer sequence, or is it possible it is slipping or something?  Do I need a new timer?  I saw on one sight that the "timer seldom goes bad, and is often misdiagnosed".  Help?  Suggestions?   Thanks!!
    Shōgun
  • Master Samurai Tech
  • 31,183 posts
Posted 10 February 2006 - 04:20 AM
You sure you don't need a new knob skirt?
http://www.repaircli...?R=154&N=541798
#3 cllvt
cllvt
  • 5 posts
Posted 10 February 2006 - 04:30 AM
That does not appear to be the issue.  There is no play or slack between the skirt and the shaft.
    Shōgun
  • 31,183 posts
Posted 10 February 2006 - 05:41 AM
Only reset for the timer is to replace it. If the cycles are running properly but are indicating incorrectly, then replace both the knob and the skirt. Been fooled by this before. Once. Only once.
#5 cllvt
cllvt
  • 5 posts
Posted 10 February 2006 - 06:54 AM
Yes.  The cycles seem to be working.  I will give the knob/shirt replacement a try.  Thanks!
#6 cllvt
cllvt
  • 5 posts
Posted 11 February 2006 - 03:56 PM
Well,  got up the courage to look this thing over again before ordering some parts, to make sure I got what I needed.  I pulled out the timer to examine for any obvious issues again, as the knob, and skirt seemed to be in great shape.  I did not see any issues, but it seemed to turn rather hard (the timer part itself).  The motor seemed to turn OK w/115V plugged in.
So, I pulled the top off the timer box.  Everything looked pretty good, so I put it back together, seemed to rotate a bit easier.   Washer start OK, cycles seem to line up fine with indicator, rinse/wrings OK ... but the knob no longer shuts the washer OFF.  In other words, to start you pull the knob out, to stop you are supposed to push the knob in, but pushing it doesn't do anything, it keeps running.  Lifting the lid still stops it.
Seems like with all the different issues, I want to point to the timer, but before I order a new one of those, could there be anything else causing this (still running with knob pushed in)?
Thanks!
                 Chris
    Shōgun
  • 31,183 posts
Posted 11 February 2006 - 05:09 PM
That's definitely a bad timer, mi amigo. Given the failure-to-turn-off that you've seen, it's likely that the bad timer is the only thing going on. :dude:
#8 cllvt
cllvt
  • 5 posts
Posted 12 February 2006 - 02:05 AM
Thanks!  :D
