stewartservice
Whirlpool WGD8300SW1 DRYER
15 posts in this topic
Flame comes on for about 5-10 seconds then goes out. Drum keeps turning but ignitor never comes back on. Have checked every thing i can think of. No fault codes. No power to ignitor after initial lighting.
try it with the vent disconnected from the dryer, are you getting good airflow out back of dryer
Yes. 4 foot run.
Definitely try it with the vent completely disconnected as Brother sh2 says because vent problems are the most common cause for this and we want to eliminate it from the picture.  Running the dryer with the vent completely disconnected is the only way to do that.
Will do. 9 a.m. in the mornin'. Thanks.
also make sure the dryer is assembled so you get airflow thru the burner
Case closed! Tech that went out prior was apparently LAZY!!! Went off his notes. Went out myself and 20 minutes later all is well. I will never believe someones elses diagnosis ever again !
So don't leave us in suspense-- what was the problem?
Correction, your case is almost closed... you just can't leave us a hang in like this.  It puts much strain on our relationship....  We must know for future knowledge.....
Thermal fuse blown. Replaced fuse and thermostat kit. Works fine. This is 2nd time this week going to a call from same tech that could not fix the problem. Usually a very good tech.
 So, what was original complaint? Igniter and gas valves can't work if thermal fuse is blown. Tech said flame came on so fuse was ok before he started troubleshooting.
Eric
Edited by fairbank56
Eric
I asked my pops-in-law about this, and he said two or three times in his 30 years he has seen the fuse to be intermittently blown which would show similar symptoms as this machine.  Doesn't happen often, but can happen.
Original complaint was no heat. Tech said he tested every thing. Would only heat for 5 seconds then no more. He had been out a couple of times and said same result each time.
I've never seen a thermal fuse act intermittently. But strange things can happen.
that does sound strange, usually either open or not. it's not a switch.
I would suspect coils.
  Probably the fuse is ok, but internal connection between fuse and wire terminal is broken and making intermittent contact. Easy enough to troubleshoot on this dryer with removable lower front panel for access. Lazy tech for sure, or poor troubleshooting skills.
Eric
