Grasshopper509
Quiet Part 1 - DU1055XTPQ4 - Buzzing 1-2 mintues into cycle
8 posts in this topic
Greetings,
    I have a Quiet Partner 1 (model DU1055XTPQ4) dishwasher. After the cycle begins the dishwasher fills up, seems to fill fine as I hear water circulating. The 1-2 minutes after start (I'm assuming the washing is to begin after a few gallons are in tub) I hear a loud continuous buzzing. Clearly other than the buzzing nothing is happening. It drains just fine when I hit the cancel button in 1-2 minutes like normal.
Perhaps coincidentally about a month ago we had a plastic lid fall through, melt a little, and a few small pieces chip off.
I broke down and cleaned out from the tub side all the way through the accumulator, chopper assembly, etc. Found a moderate amount of junk including plastic and pea size of ceramic, noting nothing significant past the chopper screen.
That didn't fix the problem. I've broken down the entire pump assembly. I WANT TO: replace the circulation motor itself, just hoping that will fix the issue. I can't really bench test the motor or anything myself. This model is a one-pump two-way motor correct? So I'm worried if it is filling and draining okay, will the motor fix it?
I don't know how to remove the impeller, as I was told there could be a jam or foreign object there. Nothing visible. I can see no blockages in the sump housing or elsewhere, and water seems to enter and exit easily.
Is replacing the motor likely to fix the problem? The impeller is included with the motor. Would getting the motor bench tested be best? To make certain it's the issue? It's the only motor in the unit right, sure sounds like a motor that's failing...
Thanks for any help you can provide!!
Might try replacing the chopper assembly first, see if that takes care of the noise.   Part number: 8268383
Edited by Samurai Appliance Repair Man
1 person likes this
For $20 that seems workable to me. It seemed to sping freely when addressed from inside the tub.
I talked to an electrician I know and he said he'd could work me through testing the motor. I've heard these motor bearings can go bad; he thingsk the fact that the motor doesn't rotate paticularlly smoothly (a little chunky, gritty feeling) suggests the bearing might be shot.
I also talked to another repair guy who was very friendly and suggested pulling the impeller; just can't figure out how to pull it apart...
Thanks for the suggestion I'll keep posting my results.
Thanks!!
If you were able to turn the impeller with or without the chopper blade installed but it was crunchy when turning the seal has failed and let water get to the front motor bearing and destroyed the bearing.
Most likely if you had taken notice it was telling you there was a problem long before it completely quit working.  Lots of the time no one notices the problem because they just get used to the new louder noise the machine starts making - it gets a few steps louder, still since you've already got used to it being loud you think nothing of it and let it continue until it no longer runs.
The humming noise you are hearing after the fill is the motor trying to run but being that the bearing is in such bad shape the motor can't start up, to much resistance to start by the power of the motor windings alone.
1 person likes this
For failed motor problems on these dishwashers, I like to replace the entire motor-sump assembly Part number: AP4434612
You could replace just the motor and save $50  Part number: AP4434021
That makes a ton of sense now that you mention it. We usually run it in the middle of the night on delay. One night several weeks ago I was up and thought wow that's loud. Then we ran it one morning and I realy was surprised and said "it always this loud?" That was the last time it actually ran and the dishes didn't get cleaned. Makes perfect sense now.
Kind of debating on the whole sump assembly or not. Want to save money but I kind of get the logic of getting new seals; hoping to get a lot of life from the machine.
Thanks for the help, you folks are great! Cheers
I ordered and replaced the entire motor and sump assembly. Having the new seals seems like a good idea. Interesting the accumulator looks a little different. Everything runs great now!!
I was able to dissasemble the motor a bit and found the culprit. There are two bearings, one was fin and one blew up. Interesting to see how it fell apart; there is material that is floating around and the sheild blew off, you could see the bearing cage sitting in there funny.
Always nice to know exactly what went wrong.
Thanks for the help again!
1 person likes this
Great job, thanks for letting us know. And good choice on going with the motor-sump assembly.
