iPad tool .............MD510LLA
21 replies to this topic
#1 certified tech group 51
  • 2,662 posts
Posted 06 July 2014 - 10:50 AM
O.K. so I buy this  iPad gizmo......................The office C.P.U.  decided not to cooperate with the office staff.........Was going out to purchase a new CPU till the old one was repaired.......So, I a looking at  new CPU when I spy this iPad thingy.....I ask the sales guy about it and he starts to speak Greek to me........................ I mean, the 8 track tape player in the old Chevy truck still operates, my cell phone is only 8 years old..........For in the field info, I have the H.P. Mini running X.P.......can it get any better than this ?????............................So here it sits on my desk, unopened, possibly unloved for I cannot  see the full potential / usefulness of this  'Miracle  of Technology'.......... :confused: .........................
#2 Applianceman97
Applianceman97
    "Hollywood"
  • 2,371 posts
Posted 06 July 2014 - 11:50 AM
Ipad is the only way to roll. 16gb is not much storage. You will have to store a lot of your info in the cloud using Evernote and Dropbox. I use both apps and they work great. I have a 16gb iPad mini that I use in the field with field harmony, Dropbox and Evernote. Between those. 3 programs (and appliantology of course) I kick some serious appliance bootay!
#3 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • PipPipPipPip
  • 956 posts
Posted 06 July 2014 - 03:37 PM
I agree, I use Dropbox and Google Drive with Evernote, here's a sample note.
Document Type Tech Sheets
Model Number KGRA806PBL00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PBL01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PBL02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PBT00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PBT01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PBT02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PSS00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PSS01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PSS02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PWH00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PWH01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRA806PWH02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PBL00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PBL01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PBL02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PBT00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PBT01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PBT02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PSS00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PSS01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PSS02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PWH00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PWH01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGRK806PWH02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PBL00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PBL01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PBL02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PBT00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PBT01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PBT02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PSS00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PSS01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PSS02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PWH00 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PWH01 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
Model Number KGSA906PWH02 Tech Sheet # 9761387 Rev #  Document Type Tech Sheets
https://www.dropbox....t - 9761387.pdf
or
https://drive.google...dit?usp=sharing
Doc# 9761387
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#4 Spannerwrench
Spannerwrench
    Mutsuhito
  • PipPipPipPip
  • 956 posts
Posted 06 July 2014 - 03:41 PM
In the above Note my Tags were Whirlpool, Tech Sheet and Oven/Range.
"Suds are not good"
#5 certified tech group 51
  • 2,662 posts
Posted 07 July 2014 - 09:16 PM
I gotta go back to the store where I purchased the iPad and ask a few questions that I shuda asked before I left the store......( Of course, some one here probably knows more than Staples sales person.. :wink:  )...............................Like, If I do not have Wi-Fi, how do I reach this 'cloud'.......Gotta see if an 'Air-card' will work............A chunk of my calls are weekend rentals ( lights are on but nobody is home)    with the Wi-Fi password protected............................ 2) Can I add more G.B. of storage internally????.............................Got another question but I forgot what it was .......... :beatnik: ....
#6 Spannerwrench
Spannerwrench
    Mutsuhito
  • PipPipPipPip
  • 956 posts
Posted 08 July 2014 - 06:13 AM
You can use an Air Card our set your phone as a hot spot and connect to the internet through your phone.
"Suds are not good"
#7 Applianceman97
Applianceman97
    "Hollywood"
  • 2,371 posts
Posted 08 July 2014 - 07:55 PM
I use my phone for a hotspot. No way to increase the internal memory.
    Shōgun
  • Master Samurai Tech
  • 30,376 posts
Posted 08 July 2014 - 09:04 PM
That's the way I roll. If 3G signal is good enough, then pulling up job rates in the Blue Book is reasonably quick.
#9 Applianceman97
Applianceman97
    "Hollywood"
  • 2,371 posts
Posted 08 July 2014 - 09:29 PM
Who the hell still has 3G? Cavemen? The new thing is 4G dude.
    Shōgun
  • 30,376 posts
Posted 08 July 2014 - 09:31 PM
I'm still running an old iPhone 4S-- it's speedometer pegs out at 3G.
But this fall, iPhone 6.  Then we'll see who's the caveman!
#11 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 922 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 13 September 2014 - 12:07 AM
So, Old thread, but now the new big question is.... iPhone 6 or iPhone 6+?
#12 B4UTRUST
B4UTRUST
    Sōhei
  • 138 posts
  • Flavorite Brew:Monty Python's Holy Grail Ale
Posted 14 September 2014 - 11:10 PM
The correct and obvious answer is Android OS for phone and android OS or Windows 8 tablet for the mobile computator. None of this apple nonsense.
Owner/Operator Flagship Appliance Repair
#13 Applianceman97
Applianceman97
    "Hollywood"
  • 2,371 posts
Posted 15 September 2014 - 01:29 AM
Windows? Double or single pained? I think double is more energy efficient.
Edited by applianceman97, 15 September 2014 - 01:30 AM.
#14 B4UTRUST
B4UTRUST
    Sōhei
  • 138 posts
Posted 15 September 2014 - 08:09 AM
Double for energy efficiency, but with a layer of tinting for privacy purposes  :wink:
#15 Samurai Appliance Repair Man
    Shōgun
  • 30,376 posts
Posted 15 September 2014 - 05:05 PM
I'm going with the regular iPhone 6 because I already carry an iPad mini Retina for document storage and study so I don't need the plus size phone.  And putting a tablet up to your head to make a phone call is just so wrong on so many levels.
#16 Applianceman97
Applianceman97
    "Hollywood"
  • 2,371 posts
Posted 15 September 2014 - 06:16 PM
Well. I will have the 5s for another year then gonna get the 6 or whatever comes after the 6. Using the iPad mini now but I'm thinking of switching to the air for a little bit bigger screen.
#17 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 922 posts
Posted 15 September 2014 - 09:37 PM
I want the performance and features of the 6 plus but only the size of the 4s or 5s... but must suffer with the bigger screen on the 6.  Going upgrade a week or two after the 6 ison the market.  none of this preorder nonsense.
#18 DurhamAppliance
    Sho' Nuff Chozin
  • 5,618 posts
Posted 15 September 2014 - 09:40 PM
My contract is up as well... Note 4 for me.
www.DurhamApplianceThrift.com
#19 Applianceman97
Applianceman97
    "Hollywood"
  • 2,371 posts
Posted 16 September 2014 - 12:06 AM
I'm waiting for the note 37. Probably should be out pretty soon. The holographic chatting will be awesome.
#20 DurhamAppliance
    Sho' Nuff Chozin
  • 5,618 posts
Posted 16 September 2014 - 12:43 AM
Then 5 years later the Iphone 48 will come out. Of course, Apple will advertise and make a big deal out of their new feature called....yeah you guessed it... holographic chatting. Then six months later the 48s will come out featuring a revolutionary idea, a replaceable battery. As usual, the Android folk simply chuckle and roll their eyes.
ps you did it once again, joking about the number of Note versions while forgetting Iphone has had many more versions but still playing catch up.
Edited by DurhamAppliance, 16 September 2014 - 12:57 AM.
