FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
Samsung DV328AEW Electric Dryer
3 replies to this topic
#1 Reloder
Reloder
  • 2 posts
Posted Yesterday, 12:15 AM
Hello.
I have a five year old Samsung W/D set that was purchased new for a new house.  The dryer is a DV328AEW.  They are on the second floor of my house and the vent is in the foundation, about 28' with two 90 degree turns.
Three weeks ago, it lost heat.  I pulled the element and found a break.  As I feared, the broken element may have been caused by a larger problem.  In sensing mode, it would go to 1 minute and hold indefinitely.  We used it on timed mode and it began doing the same thing.  I thought this must be a control board or dryer sensing strip.  So I pulled out the 87V and put it to use probing.
I pulled out the stainless sensing strips and cleaned them with a scotch brite.  I measured the Ohms and when I placed my moistened finger across the resistance would start at 400 Ohms and climb.  I decided this was not the problem so it must be the dryer duct or the control board.  I took the liberty to clean the foil dryer hose and make sure it wasn't kinking.
The control board was cheap ($60) so I replaced it.  No help, Problem persists.  On a side note, I build PCBAs for a living and that board is a sad piece of severely dated technology.
DW has the dryer duct people coming on Wednesday.  Just wondering if I am missing something else?  I suppose I will travel to HD or Lowe's to get a metal rigid duct this weekend.  Does it sound like the vent to you experts out there?
    Shōgun
  • 28,706 posts
Posted Yesterday, 06:05 AM
You said you found a broken element but you never said you actually replaced it.  Did you?
Part number: DC47-00019A
#3 PDuff
PDuff
  • 1,755 posts
Posted Yesterday, 03:20 PM
Definitely replace the damaged element and have the vent inspected and cleaned.  After that, provided there were no error codes displayed, you should be fine.
#4 Reloder
Reloder
  • 2 posts
Posted Today, 11:45 AM
Sorry for not making that clear. I replaced the element. The dryer has too much heat now. It goes to one minute and holds.
2 user(s) are reading this topic
2 members, 0 guests, 0 anonymous users
