Kenmore 70 Series - water won't empty...
4 replies to this topic
#1 Guest_Dee_*
Guest_Dee_*
  • Lurking at the Threshold
Posted 10 May 2005 - 01:26 PM
Hi!
Nice site...can someone help?
I have a Kenmore 70 Series Heavy Duty washer Model 110. 22712 100, Serial # CL 2550074, Type 111
- the water is not emptying out. It agitates (me) but will not empty. Does this sound like something I can repair myself? I called the Sears service center but the soonest they can get someone out here is next Tuesday. What's up with that? I thought all they did was sit around all day waiting for us to call them! Thanks much ~D :)
#2 Moostafa
Moostafa
    Senpai
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 10 May 2005 - 03:28 PM
Hello, my unspinning friend. If the washer goes completely silent during the spin portion of the cycle, then may I suggest that you read this enlightening tome from our most dear and gracious host, Samurai Appliance Repair Man? Very well, then, I suggest that you read this enlightening tome from our most dear and gracious host, Samurai Appliance Repair Man.
Allahu Akbar!
#3 Dee
Dee
  • 2 posts
Posted 10 May 2005 - 04:03 PM
Arigato repairman from afar! But after reading that I think I shall leave it in the hands of an expert repairman. The only Ohm I'm familiar with is the one I practice during my yoga meditation!!
I shall set out tomorrow in search of one that can hopefully get here before next Tuesday.  :?
Incidentally, the washer died on the final rinse, the water never emptied out so I don't know if the spin cycle works. I can rotate the dial and do hear clicking but it will only respond to the final rinse cycle at which time it agitates but still won't drain the water at the end of the rinse cycle.  ~D
  • 24,258 posts
Posted 10 May 2005 - 05:04 PM
Bad lid switch. Moostafa linked you to the correct "tome." Piece of pie, a single mug on the SUDs-o-meter.
#5 Dee
Dee
  • 2 posts
Posted 11 May 2005 - 02:06 PM
YOU ARE TRULY GIFTED! It is the lid switch...I managed to tie it with a little string to hold it in place so I can drain the water and finish this load. A quick fix - but the washer works, I'll run out tomorrow and get a new switch. Hopefully replacing it will be as easy as finding the problem.
THANK YOU THANK YOU THANK YOU!!!!
:party:
My sincerest gratitude, ~Big Smile~ Dee
