Troubleshooting a Glass Cooktop Element that Won't Stay On
range glass cooktop thermal limiter ribbon element troubleshooting
No replies to this topic
#1 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 29,830 posts
Posted 19 July 2014 - 07:59 AM
Troubleshooting electric cooktop elements is usually straightforward.  Calrod elements (the coiled elements) are simple resistive heating elements.
The elements used in glass cooktops are a little different.  For one thing, the heating element is an open ribbon element set into a base material instead of a calrod element where the entire heating element is sheathed in insulation and metal.
Another big difference is glass cooktop elements is that they have a thermal limiter built into them.
One thing to be aware of is how that thermal limiter works because, if you don't, you could end up misdiagnosing a "problem" that doesn't really exist.  This video explains how these glass cooktop elements work and how to troubleshoot the element and infinite switch.
Also tagged with one or more of these keywords: range, glass cooktop, thermal limiter, ribbon element, troubleshooting
