GE Profile Triton dishwasher not draining completely
20 replies to this topic
#1 Sparkland
Sparkland
    Ikkō-ikki
  • 32 posts
Posted 10 May 2005 - 01:46 PM
My dishwasher will not drain completely out of the bottom after finishing the wash, rinse or dry cycle.
Model #GSD5120D02BB, it is a GE Profile Triton XL
I took the screen out at the bottom and found no obstructions. Removed the hose from the drain motor and found no obstructions. Also checked the drain tube and nothing there. The air gap seems to be okay. It is one that is high just under the counter top and drains into a separate line.
Was wondering if it could be the pump or something else.
Serial number is MAZ90523B
This unit is about 3 years old.
#2 Pegi
Pegi
  • 13,120 posts
Posted 10 May 2005 - 06:19 PM
 Deleted, is not the same style as for the information I posted. Sorry.    :?
#3 kingsx
kingsx
    Yamabushi
  • Master Appliantologist
  • 88 posts
Posted 11 May 2005 - 03:12 PM
You could attach a hose directly to the pump to see if it will drain completely
uphill into your kitchen sink.
First see if an obstruction such as broken glass is just inside the drain outlet on the pump
it should be clear when the solonoid opens the waterway or if you do it manually
Did you look inside all the tubing under there?
#4 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 11 May 2005 - 04:28 PM
    http://www.partselect.com/ModelFrames.aspx?ModelID=765528&ModelNum=GSD5120D02BB&mfgModelNum=&ManufactureID=2&Selected=00107342i03&Position=0&mfg=GE&Type=Dishwasher&Mark=2 might you find interesting first of all.  "Empty noise" does it make?  Water some is normal.  Remains how much water?  Soapy is it?
#5 Sparkland
Sparkland
    Ikkō-ikki
  • 32 posts
Posted 12 May 2005 - 10:29 AM
I would not say the water is soapy. Seems clear enough to me. About 3/4 - 1" of water is the maximum amount left in the bottom. It does not make any unusual noises.
Thanks, Brad
#6 asphaltech
asphaltech
  • 2 posts
Posted 16 May 2005 - 02:09 AM
Have same problem with my dishwasher Triton profile.
i think its timer but not sure. Work around for it is to
restart dishwasher with rinse only and as soon as it starts
push reset and it will drain water out.javascript:emoticon(':?', 'images/emoticons/confused.gif')
confused
#7 Sparkland
Sparkland
    Ikkō-ikki
  • 32 posts
Posted 18 May 2005 - 04:25 PM
Thanks for the tip. I tried the start on "rinse" and then "cancel" and it drained perfectly. Do you think it is the timer? Are those difficult to replace? Can I get that part on this site?
Thanks, Brad
  • 24,720 posts
Posted 19 May 2005 - 04:03 AM
Scroll down-- you can get any part you need through that table.  And you can return any part for any reason.
#9 mopar X
mopar X
    Yamabushi
  • 76 posts
Posted 19 May 2005 - 07:18 AM
Dishwasher has a rubber flapper style check valve located between the soil collection chamber and the drain line. These go bad and restrict the water from draining out. Also some models have a valve under screen in back called a piston valve if this has debris keeping it from opening and closing or is deteriorated you will need to change this also.Start washer let fill initiate pump out water should exit rapidy into drain if its slow check both items above
#10 Guest_Ash_*
Guest_Ash_*
  • Lurking at the Threshold
Posted 21 May 2005 - 07:52 AM
Hi
I have problem with draining as well.  I think that it might be stuck pump because I had not used the unit for some time.  GE says to put citric acid in the system to loosen the pump.  Will this wordk?  Has anyone done anything different to releive a stuck pump?
Thank you,
Ash
#11 Pegi
Pegi
  • 13,120 posts
Posted 21 May 2005 - 03:48 PM
Ash, what is your model number.  There are different pump/motors and yours sounds like a different style???  PLease post this.
#12 jrmechanic
jrmechanic
  • 3 posts
Posted 22 May 2005 - 06:03 AM
Oh Mighty and Powerful Appliance Guru,
My GE Triton, model # GSD5134D00WW, has resisted my attempts to repair.  It also refuses to drain completely.  I have checked hoses, have no air gap, made sure trap was clear, tried rinse-reset trick, and replaced drain solenoid.  Stubborn dishwasher still confounds me.
Is the piston assembly the next logical step?  Check valve?  What tips do you have for troubleshooting to locate the specific culprit short of replacing parts to see which one works?
P.S.  Please speak slowly and use small words -- I'm a beginner and just learning my way around appliance maintenance.
#13 Pegi
Pegi
  • 13,120 posts
Posted 22 May 2005 - 08:13 AM
If I could make a suggestion to the people needing help out there.  Start a new topic.  We are trying to find answers for several different people with different dishwashers and it makes it very difficult to try to answer ONE poster when others join the same thread with different units.  I will stop replying to threads where other posters start asking questions about their different unit with what sounds like the same problem in someone elses post.  :knifehead:   Pegi , At Sams Appliance and A/C Repair
#14 Samurai Appliance Repair Man
  • 24,720 posts
Posted 22 May 2005 - 04:12 PM
Good suggestion!
#15 Pegi
Pegi
  • 13,120 posts
Posted 22 May 2005 - 06:24 PM
Thank you for your support on this huge problem...Pegi
#16 jrmechanic
jrmechanic
  • 3 posts
Posted 23 May 2005 - 08:07 AM
Sincere apologies.  My mistake. :(
#17 Pegi
Pegi
  • 13,120 posts
Posted 23 May 2005 - 09:55 AM
Thanks for the reply, you did not know so do not feel too bad, but it sure makes it difficult for us and believe me, you are not the first to do this!!!    ;)  Pegi
#18 asphaltech
asphaltech
  • 2 posts
Posted 27 May 2005 - 12:26 PM
I have found the problem with my dishwasher.
The check valve is worn and letting water back in the tub while it is draining there for not draining all the water out. Temp repaired with a cork until i can get a new check valve. Thanks for all the help
#19 Guest_masood_*
Guest_masood_*
Posted 07 November 2005 - 03:34 PM
my ge triton wont drain water. model# gsd5500g00ww. it's only 3 years old! I checked the pipe and all is clear. I've already replaced the piston and nut assembley. it sounds like water is trickeling up to the disposer.  what can be the problem?:yikes:
#20 Pegi
Pegi
  • 13,120 posts
Posted 07 November 2005 - 05:11 PM
The problem is, it appears, you are posting with that quote,  in a 5 month old thread as a joke, no bite here my friend....:cool:
