frigidaire GLTF2940ESO washer won't enter diagnostic mode
6 replies to this topic
#1 scott johnston
scott johnston
  • 3 posts
Posted Yesterday, 10:58 PM
My  stopped working.  Pushing any button (or combination) on the face gives only "Err"  which I take to mean error but it does not yield a code so isn't much help.  Sometimes I also get "Loc".  Does this mean the door lock is faulty?
The machine will not enter the diagnostic mode by turn the dial to the correct setting according the manual.
Last year I had to replace the pump motor and the error code system worked fine.
Any ideas?
#2 applianceman97
applianceman97
    Baby Sensei
  • 1,592 posts
  • Flavorite Brew:Citrus Mistress
Posted Today, 12:01 AM
Loc could mean control panel lock. Is the led light right above the cancel button illuminated?
You can try unlocking the control by holding down the options and select buttons.
If this does not work you may need to replace the main board.
Edited by applianceman97, Today, 12:01 AM.
http://www.tandnappliance.com
#3 nickfixit
nickfixit
  • 2,144 posts
  • Flavorite Brew:Glen Livit
Posted Today, 06:12 AM
It's common for a Frigidaire product to be unable to enter diagnostics, even when it's working fine. It leaves you without the diagnostic codes for help.
#4 Budget Appliance Repair
  • 4,679 posts
Posted Today, 07:32 AM
I've seen this exact same thing before, bad main board if the user interface lock isn't actually locked.
William Burk (Willie)
Eureka, CA 95501
    Shōgun
  • 28,816 posts
Posted Today, 07:37 AM
Same here, seen the same thing.  Bad main board Part number: AP4358809
#6 scott johnston
scott johnston
  • 3 posts
Posted Today, 09:10 AM
Thanks to all of you for this very helpful information.  I'll order the main board then.  We did have a power outage on the our electric grid due to forest fires so their may have been a power surge that cooked the board.  So, this seems like a safe bet.
#7 scott johnston
scott johnston
  • 3 posts
Posted Today, 09:36 AM
Ok, I have ordered the new main board as suggested.  Now I need a little more help.  Where is this part located.  Last year I had to replace the drain pump and motor so know who to access the lower reaches of the machine but suspect this part might  be behind the lights and buttons up top.
