DLG1002W Front Control Dryer Disassembly
3 replies to this topic
#1 Hansie
Hansie
  • Apprentice
  • 3 posts
  • Flavorite Brew:Yuengling
Posted Today, 10:29 AM
I am trying to crack this open so I can change it to LP gas.  The included instruction are clearly not for this model.  Anyone know the secret?
14799_10203617648355709_4691661971918843
10349069_10203617648435711_4210563832959
10527439_10203617648795720_1103711645673
#2 john63
john63
    Dean of LG Appliantology
  • 2,094 posts
Posted Today, 07:32 PM
Unsure how to disassemble dryer?
Or not sure of how to convert from natural gas to propane?
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 john63
john63
  • 2,094 posts
Posted Today, 09:28 PM
Judging from your photos---the front cover is ready to be pulled forward and lift up.
Once the front cover has been set aside---the front drum support (2nd cover) can be removed by removing 4 screws from the
"ears" on the sides.
There's usually at least one additional screw located at the blower housing which must also be removed.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#4 Hansie
Hansie
  • Apprentice
  • 3 posts
Posted Today, 10:21 PM
Ack, I got so discombobulated, I didn't even post the right model.  It should be DLG1102W.
Your videos explain the conversion process pretty well, I just can't get to where the burner is.  I got the top off, but I can't see how the front is secured.  The instructions that came with the new nozzle describe the opening process but the pictures and text resemble models that have a round, clear door and controls that are front facing, not upward facing but at the front of the top surface as is with my model.
How much force should it take to pull it forward?  I am afraid if I yard on it any harder I am going to bend it and live the rest of my life in the doghouse.
Edited by Hansie, Today, 10:21 PM.
1 members, 0 guests, 0 anonymous users
