Learn how to be your own tech line...
john4180
KitchenAid KUDI01FLSS6 Dishwasher leaking at bottom of door
3 posts in this topic
I've got a Kitchenaid kUDI01FLSS6.  It randomly leaks at the bottom of the door.  I've looked all over the place and have done all that has been suggested.
replaced door gasket
tightened the pump
checked the bottom spray arm (and top) for cracks or holes
nothing seems to work.  From what I can tell the water comes up above the front lip and then goes around the door and out it comes.  Anyone have any idea how to fix this?  There is a hard plastic type gasket on the bottom of the door but it seems fine and I cannot find a replacement for the life of me.  Could this be a float switch issue?  It's not turning off correctly so it's overfilling?
Any help would be appreciated.
thanks.
I've tracked some of these leaks down by removing the inner door panel and looking for soap scum tracks.  This leads you to the source.  Could be the dispenser or vent.
Another source I've seen is the basin float.  You would catch this in the act by using a mirror to inspect this area while the dishwasher is running.
And check the usual:  gookus in spray arms causing jet sprays against the door door gasket.
Make sure it is level and "square" in your cabinet opening.  Incorrect installation causes a lot of DW door leaks.
