GE elec dryer: top of dryer gets too hot DBXR463EG6WW
dryer top gets too hot
4 replies to this topic
#1 frunch
frunch
    Kohai
  • 257 posts
  • Flavorite Brew:River Horse Hipp-O-Lantern Pumpkin Ale
Posted 29 July 2014 - 05:35 PM
I had an interesting call come in for a GE electric dryer, the customer said it got very hot to touch on the top panel, specifically in the area close to the control panel and also on the metal panel behind the control panel. When I went and tested it, it didn't act up. It heated and tumbled, but the panel did not get hot--just a little warm if anything. I used my digital thermometer to monitor the temperature, and it was cycling the heat on and off consistently. My first thought was a clogged vent or exhaust duct in the dryer, but everything was clear. Not only was it clear, but the vent was also very short and went out an outside wall. The customer was/is afraid of it starting a fire. I assured them that there are several thermostats and safetys that should prevent that from happening, but I'd still like to get to the bottom of it regardless. I even tested the dryer with the timer set to 40 minutes and *did not* turn the dryer on to see if maybe it's powering the heating element when it's turned off. Rare scenario, but I've seen it before. It does not appear to be powering the element when it's off.  I checked for the heating element shorting to metal, and did not find any evidence visually or with my meter. With the dryer re-assembled it, I tested it one more time, and it is not making the top panel hot--again, it was warm at most. I just realized now that I never tested it with clothes in it. I presume that would force the heat to stay on a bit longer, and perhaps produce the results they had called me over for.
Is this thing just a piece of crap? Or is there something I overlooked? I'd love to get to the bottom of this, can anyone offer any suggestions? Again, the model is DBXR463EG6WW.
Thanks!
Trevor
P.S. What I'm referring to by the 'top panel', I mean the big rectangular panel in front of the control panel that gets removed when taking the dryer apart by removing the 2 philips-head screws behind the door. Just trying to clarify as well as I can, hopefully that helps... :turned:
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,905 posts
Posted 29 July 2014 - 05:55 PM
You should have double checked that both elements are ok. Sometimes one of the elements will short to ground before it breaks. Remember, most GE electric dryers use 2 heating elements in a parallel circuit.
Scott Wolf
#3 frunch
frunch
    Kohai
  • 257 posts
Posted 30 July 2014 - 03:52 PM
Thanks for the info, Scott! I'm going to schedule with the customer to take another look at it, and in particular take a much closer look at the heating element. I'll check back in when I get the chance to go over there.
#4 AQAppliances
AQAppliances
    Ikkō-ikki
  • 23 posts
Posted 13 August 2014 - 07:51 PM
Chalk that one up to a crazy customer.
#5 jambatt
jambatt
    Senpai
  • Scholar of Appliantology
  • PipPipPipPip
  • 889 posts
Posted 14 August 2014 - 05:15 PM
Have had the same issue. Usually found vent issue or customer cut unit off before it went through the cool down period (no heat during last 5 to 10 minutes of the cycle). Sometimes the cycling thermostat (high limit) is bad.
Don't take life too seriously, none of us get out alive !
Also tagged with one or more of these keywords: dryer, top gets too hot
