Dacor ECS1305BK OVEN door does not fully close
8 replies to this topic
#1 Neon john
Neon john
  • 19 posts
  • Flavorite Brew:Pilsner
Posted Yesterday, 07:57 AM
After 12 years I finally decide to fix it. It feels like the door gasket is preventing the door from closing all the way. I adjusted the gasket and the door closes to within 1/2 inch now. I can push on the door and will will fully close but it springs back when I release it. I have heard that I am not the first one to have this problem. Did dacor maybe install a gasket that was too thick at the factory?
    Shōgun
  • 28,876 posts
Posted Yesterday, 08:16 AM
Moved to Kitchen forum.
You need to install the new door hinge kit Part number: 701034
Part number: 701034
The springs have gotten weak and aren't pulling the door in tight any longer.
#3 Neon john
Neon john
  • 19 posts
Posted Yesterday, 03:17 PM
That was my original thought. Since new this unit has had the problem of the door not fully closing. When I push on the door there is a soft resistance like it is pushing on the gasket. There is no way that installing new spings would overcome this resistance which leads me to believe the problem lies elsewhere. After adjusting the gasket the the distance to fully closed was reduced from 3/4 of an inch to 1/2 half inch. Is it possible that the factory installed the wrong spring?
#4 Scottthewolf
Scottthewolf
    Senpai
  • 2,753 posts
Posted Yesterday, 03:59 PM
On almost ALL self cleaning ovens, the door does not close tightly until you put it into self clean, this is a normal condition.
Scott Wolf
#5 Neon john
Neon john
  • 19 posts
Posted Yesterday, 04:12 PM
Thanks.....that answer makes a lot of sense. The more I learn about Dacor appliances the more I realize that I made a huge mistake when I remodeled my house and installed their stuff.
#6 Spannerwrench
Spannerwrench
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 624 posts
Posted Yesterday, 08:03 PM
There's nothing at all wrong with DACOR, replace you're hinges and be good once again.
In my opinion, DACOR has the most accurate ovens you can buy.
Edited by Spannerwrench, Yesterday, 08:04 PM.
"Suds are not good"
#7 Neon john
Neon john
  • 19 posts
Posted Yesterday, 08:08 PM
Not to start an argument but I strongly disagree with you.
Try this link to see what others have to say. http://www.consumera...ners/dacor.html
#8 Scottthewolf
Scottthewolf
    Senpai
  • 2,753 posts
Posted Yesterday, 11:07 PM
I think I am starting to show my age, but the most reliable appliances were the old fashioned ones from the 60's, 70's and 80's before all these electronic controls, energy saving fan motors, and before everything was made out of cheap plastic. Today, the brand name doesn't mean much anymore.
Scott Wolf
#9 Neon john
Neon john
  • 19 posts
Posted Today, 10:32 AM
Alas......just last week my wife was making the same remark about my age.
1 members, 0 guests, 0 anonymous users
