frunch
LG refrig LFC20760SW completely dead, no lights, warm
12 posts in this topic
I checked out an LG refrig today that was completely dead. I have power at the outlet, and I have power coming into the muthaboard. I'm assuming it's a bad board (or in the bit of research I did, a bad fuse on the board--I didn't check the fuse though!  :rolleyes: ) .....anyways, I'm getting 120 vac coming into the board but that's it. Re-seating connectors didn't do anything. Should I order up a replacement board? Anything else I should be checking? Unfortunately I don't have very much experience with these refrigerators, or most LG products for that matter...
Thanks!
Trevor
Sounds like a board to me. Typically, you will find a blown fuse on them if you have nothing running as well as no lights.. Some I've replaced the board and others the fuse was easily replaced. I don't mess with soldering new fuses in.
Edited by BryanS
Thank you, sir! That was a rapid response! I'm gonna order the board today in hopes that I can get it in time for the weekend.
Thanks again!
No problem. You caught me on a lunch break :)
I routinely replace those fuses and the board has always been fine.
Good to know, Samurai! Do you desolder the old one and solder in a new one?
By the way, you were right on the money, BrianS-new board fixed the problem!
If i where you. I'd replaced fuse on brd n keep it as a spare.
Think I'm gonna do that! At very least I can use it as a test board for the next LG refrig I run into with the same problem.
I've done a couple where I just soldered in a jumper wire, eliminating the fuse altogether. But I don't recommend that and I've altered my technique. I now solder in an automobile fuse holder and replace the fuse with one of the same rating.
I have done the same as Samurai.   I carry my solder iron & fuse holder with fuse with me on LG refer calls.
One question I've overlooked: what causes the fuse to blow? Is it due to power surges or brown-outs?
Thanks for the tip too, Samurai! That's a great idea!
That's what I figure it is. Most of the people I've come across said they had recent power outages or get a lot of brown outs.
