Maytag Gemini Oven Problems MER6755AAW
top oven only bakes bottom oven only broils
1 reply to this topic
#1 ESP
ESP
  • 2 posts
  • Flavorite Brew:Coors Light
Posted 31 July 2014 - 07:11 PM
I purchased the referenced oven new in 2007.  Today, the top oven will only bake (no heat at all at the broiler) and the bottom oven will only heat to 225 and no higher.  Problems happened at the same time (not one, then the other).  Any thoughts?  Thanks
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,854 posts
Posted 31 July 2014 - 10:50 PM
The clock/electronic control has probably failed. You might also need a new broil element for the upper oven.Part number: W10166967
Part number: 74009993
Part number: W10201551
Scott Wolf
