Sign in to follow this
Followers 0
codeMonkey
How to remove the inlet valve wires on my washer? mod# 110.26002011
3 posts in this topic
I'm replacing the cold water inlet valve on my Kenmore washer.  I read your how to here, but it simply said to remove the wires.
My problem is that the tabs the connectors wires are in are _very_ firmly attached to the tabs on the old valve.  That combined with the fact that the wires are about as thick as a hair and my paws are kind of gnarled and arthritic makes me afraid to just force them off - I might break the wire(s).
Is there a trick or a special tool needed to do this?  There's a picture below of what the connectors look like.
Also while I have your ear, when I connect the new ones, should I give the metal tabs on the valve a smear of dielectric grease before snapping them in?
Thannk you.
(Sorry for the giganto image.  I don't know how to size them with this richtext control.)
I got it.  I sorta wiggled 'em off with a pair of needlenose pliers.
Thanks you all.  Hope you have a good weekend.
No trick or tool.  Just pull on the connectors, somewhat carefully to avoid breaking them.  Try pliers for a better grip or a small screwdriver under the connector between the terminals for leverage.
Followers 0
