twodotmike
LG WM2050CW tool P/N 383EER4004A
22 posts in this topic
LG Washer model WM2050CW - ...My son-in-law is thinking of replacing the tub to door boot due to moldy smell on clothes. Washer has been through many 'Clean Cycles" and the boot has been cleaned at various times with either white vinegar or bleach. Not much, if any, help. Trying to help him out, I read up on replacing the boot and came upon two tools for removing the clamp rings. I see that the boot can be replaced without the tools, they just supposedly make it easier. I'm all for making jobs easier and one can never have too many tools!
I ordered both tools for him. The tool number Part number: 383EER4001A
(straight prongs) makes sense as it "expands" when you squeeze the plier handles together. However, I don't see a use for the tool number Part number: 383EER4004A
(bent prongs) in removing the boot springs. This tool's prongs actually "contract" when the plier handles are squeezed. I don't see them as being useful for removing the boot spring, as the don't "expand" the spring. They appear to be for an inside type spring or clip that must be "compressed" to be removed from a groove on the inside of a component.
Exactly where is the bent pronged tool, Part number: 383EER4004A
, used? Thank you.
The bent pronged tool is used to reconnect the inner door boot clamp.  Essential for this task!
Shōgun...Thank you for the info.
At first I thought that the 2 tools were both "expanders" and that they just were for two different size retaining rings, but now that I have the 383EEER4004A tool (bent prongs) in hand (the straight prong plier is due to arrive Monday) I see that isn't so.
As the spring on the retaining loop needs to be expanded in order to come off the outside of the boot, and as the 383EEER4004A pliers contract when the handle is squeezed, I cannot visualize how this will work. When he actually does the replacement I guess I will find out. The 383EEER4001A plier (straight prong) makes perfect sense as it will "expand" the spring to allow it to be removed over the outside of the boot.
I really do appreciate your input, I just cannot visualize "contracting" pliers allowing the spring to be "expanded" in order to be removed or reinstalled. Maybe we are not talking about the same springs? I am talking about, I believe, seal P/N 4986ER0004F and its retaining rings/springs. This is the wide boot you see when you open the washer door.
As I said before, when he actually replaces the boot I'll see.
twodotmike
The inner tool I have would not pull the clamp together enough on the inner clamp. I ended up removing the center spring and bending the 2 arms of the pliers closer together. This gives you more pull on the clamp. Made it much easier for me but maybe mine just had a flaw.
The inner clamp tool doesn't really work that great, I think I'll try applianceman97's modification. An easier way than the tool involves using a self-tapping screw through the loop on the spring end of the clamp to hold it in place.
I put the arms of the pliers in a vise and just tightened the vise up to bend them.
You get more pull if you hook the tool under the eye on the clamp vs in the eye. Just another tip that makes is easier for me.
Applianceman97
Nickfixit
Thank you both for the suggestions. I will keep the self tapping screw idea in mind as well as bending the plier prongs if necessary.
twodotmike
The Outer spring tool works fine, but the inner until now I have to use a rope to hook-up the spring, I may try your suggestions.
Today, Saturday, August 9, my son-in-law changed his LG washer door boot. The process was straight forward, as expected. Both outer and inner boot retaining ring/spring assemblies were removed and replaced using the straight pronged tool, P/N Part number: 383EER4001A
. This tool works well for the outer seal and is adequate for the inner seal, but still not ideal (it should expand a little more). Straight from the OEM factory, at this tool's cost, a user should not have to make any modifications to the tool for it work properly.
I tried the bent pronged pliers, P/N Part number: 383EER4004A
, on the inner retaining ring/spring assembly to see how it would work, and I still do not see how this tool will work to remove or install either of the boot seal retaining ring/springs. These pliers contract the spring, making the retaining ring tighter on the seal lip. They do not expand the spring, loosening it, so that the ring/spring unit can be removed over the outside of the boot seal.
Perhaps, some day, I can see a professional repair person use this tool correctly and then I'll know, but, for now, should we have to change the boot seal, again, we will just use the straight pronged tool, P/N Part number: 383EER4001A
Again, a big THANK YOU to all who replied to my inquiry. I do appreciate all of your suggestions.
twodotmike
TwoDotMike, I have been watching this discussion with great interest, I've seen the pictures of those tools before and thought the exact same thing you are asking and discussing about.
I don't have and have never seen those two tools in person but had seen the same pictures previously and couldn't ever figure out how or where the bent prong one that pulls the clamps tighter could ever be used?
I have made do with the the xpander rod tool mentioned previously and doing the front one by hand with small screwdrivers.
the bent prong tool for the inner clamp is because the inner clamp has a hook, you contract the spring and then unhook the spring letting you take it off
sh2sh2,
Now that the washer is closed up, I am trying to visualize the inner retaining ring/spring unit. I do remember seeing a loop in the retaining ring. I don't recall which end it was near, but, now, I'm guessing it is near the "hook" end of the retaining ring.
Using the bent pronged tool, are you saying that you place one prong of the tool in the loop and the other prong on the end of the spring and then, essentially, pull the spring over the hook?
If that is correct, then "haste does make waste" as we didn't think through the purpose of the loop, seeing as the outer retaining ring does not have a loop.
Thank you for your input.
twodotmike
Budget Appliance Repair,
I had thought of getting that particular expanding tool, too, as a backup to the two LG tools, in case the LG tools didn't work well for us. Since I hadn't replaced the LG boot before, I had no idea whether or not those springs had a little or a lot on tension on them, thus I purchased the LG tools for ease of the boot replacement.
Do you like that expansion tool and does it seem to work well? They reason I ask is now that my son-in-law's LG washer boot has been replaced, I've noticed that the boot on my Maytag Neptune washer is torn! Luckily the tear is near the top and the washer is not leaking. Watching a video on replacing the Neptune boot, I don't believe its retaining ring/spring setup is as awkward as the LG, but I guess I will find out in the next week or so.
twodotmike
sh2sh2,
twodotmike
yes that is correct
sh2sh2,
THANK YOU for the confirmation of the inner spring removal sequence! Now, I feel very foolish for not recognizing the set up when I first looked at it.
Oh, well, I guess old age is finally catching up to me!  Next boot change, we'll be ready!
Thanks, again.
twodotmike
My sentiments exactly.    Now if you can explain that to my Babes....says I have enough tools.
It wasn't easy on the LG that I used the expander rod tool on.   Should have used gloves when turning the thumb wheels tighter, by the time I was done I had torn skin off the fingers!  Man those springs are strong!
Thanks for the heads up on wearing gloves. Just looking at a picture of the tool, I thought maybe it was too long to maneuver easily and control.
When I do my Maytag Neptune MAH5500BWW, I'm going to see if the LG boot outer tool will work, but I have the feeling that the spread of the springs are too different in their sizes. The video I saw on the Maytag makes it look like a vise grip tool and a pair of needle nose pliers will work well, plus only one spring to work with.
twodotmike
applianceman97,
Thanks for your comment and the tool suggestion. Looking at the spreader tool, it appears to be fairly long. About how long is it? It's not too long to control easily? Obviously it would depend on the strength of the spring, but is the thumb wheel fairly easy to rotate?
twodotmike
Not sure how long the tool is. You do have to point the long end the opposite way the door swings. The thumb wheel is very easy to rotate.
Thanks to all who responded to my inquiry on the use of the LG springs tools, especially "sh2sh2" who confirmed the proper use of the "bent pronged" spring tool.
As well as replacing the boot seal on my son-in-laws LG washer, I had to replace the boot seal (torn) on my Maytag Neptune washer. I was hoping the LG tools might be usable on the Maytag to stretch its one spring, but no such luck. I used a couple of small vise grip tools on the Maytag and they worked okay, it's just that the spring expanding tools make it less cumbersome to work with the springs. Since it's not an everyday job, it's no big deal.
Again, thanks to all,
twodotmike
