tlux63
Bosch SHE4AM15UC/03 goes to Clean after 2 minutes
6 posts in this topic
When I start the dishwasher, it goes through a short drain cycle, tries to fill, does another drain cycle, sounds like it tries to fill again, and stops and lights the Clean light. This takes a little over 2 minutes. Today I discovered that I can get it to complete the cycle if I open and close the door during the second drain cycle. I tested the drain pump by adding water and holding up the float valve. The water drained easily. I ran the diagnostic and it indicates a problem with the drain pump. I've replaced the control panel, the power module, and the door latch (Hall sensor). No luck. I'm considering replacing the drain pump or the fill valve at this point, but I'm running out of ideas.
I forgot to mention that this started out as an occasional problem (1 out of 10 times) and has steadily gotten to the point where it occurs about 19 out of 20 times.
I have the same problem with mine. I have spoken to Bosch "tech support" a few times. We have not been able to determine the actual cause. They say it "could be the drain pump, Circulation motor, or the power control board. They suggested replacing one at a time to determine. I suggested they send them to me free since they can't give me better advise. So I just live with it since I can't afford to replace up to 3 parts to attempt a repair. I listen to mine, I start the cycle, listen for the drain pump, when that finishes the circulation motor comes on, AS SOON as it stops I open the door for 2 seconds then close it and the cycle always starts and runs through. If I come up with a solution I will make it known.
Interesting. It sounds like you have exactly the same problem. I'm glad to hear it always runs through the cycle when you open and close the door correctly. I have only tested it twice.
If I could figure out how to get it off, I might try replacing the drain pump. It's less than $40 and returnable to searspartsdirect if it doesn't work. Any ideas on how to get it off? There's some kind of tab system in place, but I'm afraid of breaking it.
(BTW, I was able to return the control panel to searspartsdirect without any fuss. I made the expensive mistake of ordering the power module from Bosch. They won't take it back. I'll be writing a letter of complaint since Sears would have let me return it. If I'm unsuccessful, I can let you have it for half price if you're interested. Doesn't sound like that's the problem, but I don't really need it hanging around.)
I was able to get the drain pump off. It rotates clockwise while holding down the white tabs. Unless someone else chimes in with another idea, I think I'll try replacing it.
Bad news. I replaced the drain pump, but that was not the problem. Anybody have any other ideas?
(Worse news. Sears won't take it back because I admitted to installing the product. Anybody need a drain pump? It was whisper quiet compared to my old one.)
