Question on disassembling clock timer on a Frigidaire FGF379WECS
7 replies to this topic
#1 dra2885
dra2885
  • 4 posts
  • Flavorite Brew:Any IPA
Posted 09 August 2014 - 04:43 PM
Hoping to get some expert advice. The LCD read-out on my range is quite dim, and I believe the issue is being caused by failing capacitors (they are only rated to 220F). I've got the clock timer unit out and I can see the capacitors, but I'm having trouble getting into the assembly itself to de-solder the old parts and solder in the new parts.
There are three tabs on the top and bottom, and I thought if I was able to push them all in the LCD faceplate would pop off, but no luck.
Any tips for disassembling this thing even further so I can get at the circuit board?
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,630 posts
Posted 10 August 2014 - 09:09 AM
I would advise you to contact fixyourboard.com or corecentric. Others may provide you with information on component level repairs. On certain appliances, I would rather have the control board professionally repaired... but that's just me.
www.DurhamApplianceThrift.com
#3 Applianceman97
Applianceman97
    "Hollywood"
  • 2,382 posts
Posted 10 August 2014 - 09:13 PM
I agree with Durham. I have used core centric many times and they do a great job.
#4 dra2885
dra2885
  • 4 posts
Posted 10 August 2014 - 09:29 PM
I'll reach out to them and see what they say. Just seems insane to spend $100+ on a fix that I can do myself for less than $5 if I could just figure out how to open the damn thing up!
#5 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 981 posts
  • Flavorite Brew:orange juice
Posted 10 August 2014 - 10:31 PM
I'd say post some detailed close up pictures of the clock-timer and maybe we can help.  I'm not familiar with this particular one but have lots of experience with taking things apart.
Doc
#6 dra2885
dra2885
  • 4 posts
Posted 10 August 2014 - 11:24 PM
I couldn't for the life of me figure out how to post an image directly to this forum, but hopefully these links work. Let me know if not.
https://www.dropbox....3l0/photo 1.JPG
https://www.dropbox....hbi/photo 2.JPG
https://www.dropbox....xdc/photo 3.JPG
You can see the six tabs I mentioned in the first photo. The third photo has a close up of one of the tabs. I thought I'd press those in and pop the front off but no dice.
#7 Budget Appliance Repair
  • 4,998 posts
Posted 11 August 2014 - 06:06 AM
That is probably one of the worst designs for a first timer to try and open up.  I just opened one like that for the first time a month or two ago, (it was the first and only one of that case style I have ever seen).
I don't really know how to explain this so I will try my best.
The center strips that wrap around the two boards and keep the boards alined by the tabs of the boards sticking through the slots is separate from the front of the case - you need to get each of those six tabs, (three on the top strip that wraps around to half of each side and three on bottom strip).
Use a putty knife to slip between the center strips and face plate to help pull the tap out while pressing with a screwdriver and to keep the front plate from snapping back as you go around to each tab.
Pay attention to the area at each short side ot the board where the upper and lower center strips meet - I think I remember there being a kind of hidden tab right in the center, (either snapping the two center strips together or kind of snapping to the lip of the front face plate).
William Burk (Willie)
Eureka, CA 95501
#8 dra2885
dra2885
  • 4 posts
Posted 12 August 2014 - 06:37 PM
Awesome, thanks. I'll give this a try this weekend and report back.
