Help Selecting A New VOM For Appliance Repair?
41 replies to this topic
#41 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 20 May 2015 - 02:38 PM
Does anyone still have Dacors instructions on how to properly test oven temperatures?  I used to have it but can't find it.  They listed a fluke that has two temp probes that you can use at the same time.  I had them but can't find them anymore.  I would like to get the meter they used but can't find out which one it was.
Thanks.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#42 DurhamAppliance
    Sho' Nuff Chozin
  • 6,054 posts
Posted 20 May 2015 - 09:37 PM
When I need two temps, I use a supco dual..... Dacor instructions should be in the dl section.
www.DurhamApplianceThrift.com
