Frigidaire Dishwasher FDB4315LFC3 Will Not Start
4 replies to this topic
#1 Ritz
Ritz
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 546 posts
Posted 18 August 2014 - 10:40 PM
1. Tested and tried new door latch
2. Tried new control board
3. Tested thermal fuse.
4. Tested float switch.
5. Does not fill
6. Does not seem to have 120v to valve.
Can make all selections for wash cycle -
Acts like its going to start then display shuts off.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,796 posts
Posted 18 August 2014 - 11:27 PM
Was the part number of the new door latch you installed #154758101 ?Part number: 154758101
There is a service bulletin to replace the door latch with this part number for the issues you noted above.
Scott Wolf
#3 PDuff
PDuff
  • 1,790 posts
Posted Yesterday, 12:07 PM
Check for proper voltage and secure wire connections at the power box.  If there's a voltage drop occurring during startup, there may be a faulty neutral somewhere.
#4 Ritz
Ritz
    Senpai
  • PipPipPipPip
  • 546 posts
Posted Yesterday, 01:00 PM
Thanks Scott I did use that same latch you mention.
Far is a bad neutral somewhere I'm a little unsure of what you mean by open neutral. I've checked and we deathly have 120 VAC. I'm also dealing with an inpatient customer which does not help.
#5 applianceman97
applianceman97
    Baby Sensei
  • 1,683 posts
Posted Today, 01:28 AM
Test your voltage with the voltage tester that has the light or bar that goes up to show power. This loads the circuit. If you have an open neutral, your vom could read 120 but still have an open neutral. The light loads the circuit and will show that you have proper power.
http://www.tandnappliance.com
