VamPLIERS anyone use them?
9 replies to this topic
#1 LLAMBERT
LLAMBERT
    Sōhei
  • Appliantologist
  • 147 posts
  • Flavorite Brew:Stone Ruination IPA
Posted 20 August 2014 - 08:31 AM
supposed to get out an stripped or rusted screw or bolt.
Why? I came into this game for the action, the excitement. Go anywhere, travel light, get in, get out, wherever there's trouble, a man alone. Now they got the whole country sectioned off, you can't make a move without a form
#2 Squeaky Clean
Squeaky Clean
    Yamabushi
  • 65 posts
  • Flavorite Brew:Benchmark Bourbon (Old Number 8) on the rocks & glass of coke on the side
Posted 20 August 2014 - 10:29 AM
Yes, they work great! I own a piece of industrial equipment that is exposed to corrosive chemicals and they use lots of Torx head fasteners. I have removed completely hollowed fasteners with this tool. It does not get used much, but has saved hours of messing around with a bunged up Torx head. Price them well, I have see them with substantial discounts on some sites.
    http://www.amazon.co...ywords=vamplier
“I’m on a path of enlightenment and would like to become an appliance repair technician. I’m looking for any and all suggestions from those who have made this journey.”
#3 BEdwards
BEdwards
    Sōhei
  • Chief+ Appliantologist
  • 169 posts
Posted 20 August 2014 - 03:44 PM
Look too cool. Just ordered a set, $34.97 plus free 2 day shipping. Like a kid in a candy store.
<p><a data-ipb='nomediaparse' href='[url="""]http://www.gfyappliancerepair.com'>Appliance[/url]Repair Winder GA</a>
#4 nickfixit
nickfixit
  • 2,200 posts
  • Flavorite Brew:Glen Livit
Posted 30 August 2014 - 08:35 PM
Looks very interesting, could pay for itself in one use. Looks like it wouldn't help if the screw was in any sort of recess. Will it grip those crappy screws on Samsung washers?
#5 BryanS
BryanS
  • 1,979 posts
Posted 07 September 2014 - 07:40 AM
I just bought a pair of these about 2 months ago and finally used them last week. They worked pretty good at gripping a rounded out set screw in this customers door handle. Most pliers will slip right off when you grab with the point of the pliers, but these grip it pretty good.
#6 DADoESTX
DADoESTX
    Kohai
  • 336 posts
  • Flavorite Brew:Iced tea with a spike of earl grey
Posted 07 September 2014 - 08:09 AM
Bought one a few months ago, used it twice.  Did the job nicely.
#7 olyteddy
olyteddy
    Kohai
  • 442 posts
  • Flavorite Brew:Earl Grey
Posted 07 September 2014 - 11:33 AM
Don says: I remember a torpedoman asking me for a Crescent Wrench.
When I asked him what size; he said doesn't make any difference, I'm
going to use it as a hammer.
Some of this may be true. Judge for yourself.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock
out of your hands so that it smacks you in the chest and flings your beer
across the room, denting the freshly-painted vertical stabilizer which you
had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench
with the speed of light. Also removes fingerprints and hard-earned calluses
from fingers in about the time it takes you to say, 'Oh sh--....'
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age .
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into
major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms
human energy into a crooked, unpredictable motion, and the more you attempt
to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else
is available, they can also be used to transfer intense welding heat to the palm
of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of intense welding
heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on
fire. Also handy for igniting the grease inside the wheel hub out of which you
want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for
testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
ground after you have installed your new brake shoes, trapping the jack
h an dle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4:
Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill bit that snaps neatly off in bolt
holes thereby ending any possible future use.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good
aluminum sheet into smaller pieces that more easily fit into the trash can
after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to
disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately machined screwdriver
tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style
paper-and-tin oil cans and splashing oil on your shirt; but can also be used,
as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted
screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed
to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a
kind of divining rod to locate the most expensive parts adjacent the object we
are trying to hit.
MECHANIC'S KNIFE:
Used to open and slice through the contents of cardboard cartons delivered
to your front door; works particularly well on contents such as seats, vinyl
records, liquids in plastic bottles, collector magazines , refund checks, and
rubber or plastic parts. Especially useful for slicing work clothes, but only
while in use.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage while yelling
'DAMMIT' at the top of your lungs. It is also, most often, the next tool that you
will need.
:woot:
#8 olyteddy
olyteddy
    Kohai
  • 442 posts
Posted 07 September 2014 - 01:23 PM
http://youtu.be/WSNgd4PU7ZY
Edited by olyteddy, 07 September 2014 - 01:24 PM.
#9 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 07 September 2014 - 02:31 PM
I have regular size and the mini. They work well if you know how to use them.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#10 Patricio
Patricio
    Opa
  • 1,623 posts
  • Flavorite Brew:Home brewed ice tea
Posted 08 September 2014 - 09:30 AM
DRILL PRESS:
WIRE WHEEL:
SKILL SAW:
PLIERS:
BELT SANDER:
HACKSAW:
VISE-GRIPS:
of your hand.
WELDING GLOVES:
OXYACETYLENE TORCH:
TABLE SAW:
BAND SAW:
disconnect.
See hacksaw.
PRY BAR:
HOSE CUTTER:
HAMMER:
are trying to hit.
MECHANIC'S KNIFE:
while in use.
DAMMIT TOOL:
will need.
:woot:
Obviously words of experience
Former Student of Master Samurai Tech School.   Current Student of  Master Samurai Tech School
http://www.mastersam...iliate.php?id=5
