herfdog
Kenmore Refrigerator 106.51183113
10 posts in this topic
The Ice maker on this refrigerator is not working. I'm wondering about the emitter boards on this unit since there is no indicator light with flapper closed or open. The emitter is turned on. All ice maker components, emitter boards, everything associated with ice maker is on the  freezer door so this unit is a bit different from anything I have encountered in the past. How can I test the emitter boards on this unit and do you have any info on interpreting those test results?
first, what is the status of the icemaker harvesting fingers?  Are they in the normal park position? If the icemaker  is stuck in harvest mode the emitter will not light up.
If the icemaker is okay and you are not getting light from the emitter then, by definition, you have a bad emitter.
1 person likes this
This is the little shorty 6-cube ice maker.  I don't even see an emitter board called out for this unit, unless I'm missing something.
Wait, I think I found it but it looks different from the conventional emitter-receiver board and each has it's own part number:
Part number: W10180607
Part number: W10296530
Is the normal position on this ice maker about 1 o'clock?
it should be about 2:30. Remove icemaker and check the inline thermal fuse. If bad, replace the connector but I would also replace the icemaker. Also make sure there is nothing preventing water from entering icemaker
Edited by DurhamAppliance
2 people like this
Ice maker Part number: W10122576
These emitter based guys can drive you crazy.
Here's my suggestion:
Kill power.
Remove the ice maker from the wire harness
Wait a few minutes.
Restore power.
Open the door.
If the emitter and receiver board are working correctly, you should see a sequence of rapid flashes (I think it's 3 flashes) indicating the emitter can't find an ice maker.  If you're still not seeing any lights, you probably have a bad emitter, but to be sure of that, you need to disconnect the right hand side board and verify 120 VAC coming into the black wire.
3 people like this
If this is like the one I worked on today in diagnostic step 15 it shows the status of the ice bin...01 full or missing or 02 empty.
2 people like this
this looks like the dual fingered harvester icemaker. I believe it has a different park position. this model has diagnostics as JJ states, diagnostic mode can reveal quite a lot and you should begin there.
1 person likes this
Thanks for all the great information!
