richseattle56
Fisher Paykel Range OR30SNDGX1 Broiler won't Light.
9 posts in this topic
Replaced igniter, which was bad still no ignition. What could be the other possibilities.
Any help would be appreciated.
Does new igniter glow? Do you smell gas? If so check for rust, mice, or insect nest / spider web inside broiler?
No gas smell. At all. Igniter does not glow. Some of these Fisher Paykel products are virtually impossible to find a parts breakdown, or anything, this is one of them.. The igniter was a major repair. not enough wire to pull through the oven cavity. Last one of these I'll work on. But any help would definitely be appreciated.
If it's not glowing, basic basics: is it getting voltage? If not, where is it supposed to get its voltage from?
Service Manual has been added to "Downloads" Potluck. Don't know how to link it. Look for " 599759-A OR30 Service". Also parts, 70873-A OR30SDNGX1FPUS.
post-59945-0-89383600-1408659217_thumb.p
Above is the wiring diagram. Bad valve?
Can't find the service manual in potluck
Edited by richseattle56
Wiring diagram is in above post. I'm thinking valve.
I don't know how to add a link. But if you go to down loads they are both in the "potluck" section 5 or so down. Begins with "OR".
Edited by stewartservice
Sorry for the late update. It was a bad valve. Replaced all is well.
