tars
ge dishwasher americana adw1100n10ww
6 posts in this topic
this dishwasher will not drain water. have taken every hose apart, replaced the motor assembly, will not drain. when it is in drain mode, its silent. once in a while it drains slow. not sure where the check valve ball should go, but it in the tube on the left of the inside of the dw that the filter assembly plugs into. any suggestions?
Did somebody recently install a new garbage disposer?
no, i took all the line apart, the knockout is not there. sometime is will drain but its real slow and intermittent.
Part number: wd12x10245
You have not mentioned the chamber collection, have you checked that?
yes, its not clogged. is that what you mean?
Will Not Pump Out
1. Check routing of hose system. It must be free from kinks.
2. Check for blocked or partially blocked drain line and air gap.
3. Check operation of check ball. Check ball should be up in drain and down in circulation.
Note: If the collection chamber is not alligned properly, the check ball will not seat and the dishwasher will not drain.
Drain Cycle:
1. Water and debris flow from the tub into the sump chamber, through the metal impeller blade of the nut grater and upward toward the lower spray
arm.
2. The drain solenoid closes the drain valve. Water is directed into the bypass drain connector and moves into the collection chamber. Water pressure pushes the filter check ball upwards, closing off the passage to the fine filter.
3. Water and collected debris pass through the drain hose connection and are discharged through the drain hose.
