Maytag LAT2301AAE Commercial Washer
3 replies to this topic
#1 wetintex
wetintex
  • 2 posts
Posted 10 May 2005 - 04:54 PM
My 2 1/2 yr old is filling the house, you have to stop the washer and then go to spin to drain. How do you take this thing apart from the front, top, back ? Are their screws or clips, what is there to do,and what to look for any help Thanks
  • 24,264 posts
Posted 10 May 2005 - 04:59 PM
Remove the front panel by using a stiff putty knife to undo the clips at the top of the panel (item 5).
#3 wetintex
wetintex
  • 2 posts
Posted 11 May 2005 - 01:48 PM
I am trying to used a 6in sheet rock putty knife to open the top with no luck, and if I do opened something what I'm looking for to fix the problem.Thanks
  • 24,264 posts
Posted 11 May 2005 - 01:57 PM
Ah, now you ask a different, more enlightened question. Before, you asked simply, "How do I take this thing apart?" presuming that you even needed to take it apart to complete your diagnosis. However, I am but a humble Exalted Grand Master of Appliantology so what do I know? What could I possibly know? Oy!
If it were me on the soivice call, I'd first run the washer on a fill cycle and then unplug it during the fill to see if the water shut off like it was supposed to. If it didn't then, according to my Appliantology 3000 chip implant, that would mean a bad water inlet valve. If it did, well, time to look at that pressure switch.
