GE #WH12X10021 -- commercial washer timer on wccd2050
wccd2050j2
No replies to this topic
#1 hitechseeker
hitechseeker
  • 12 posts
  • Flavorite Brew:Stella Artois
Posted Today, 01:02 AM
I have a GE commecial washer model wccd2050j2.
It does not start a cycle after coins have been inserted. Originally, I thought was the lid switch an replaced that. However it looks like the timer gets  stuck somehow. When I moved the time manually by a few teeth ( turned the gear ) it started working. The machine is quite new and I did not expect the timer to go bad this quickly. Can the time be repaired or reconditioned somehow, rather than having to buy a new one at over $100 ?
Is it possible that I can lube the gears or have some sort of loose coupling between the timer motor and the cam gear ?
Your help is much appreciated..
4 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
    Facebook (2)
