aqrepairguy
Maytag Bravos Washer Model MVWB850YW1 LF code
1 post in this topic
This unit is throwing a LF code. Unit will start to fill up and at the start of the agitation will throw the LF code and drain.
Have check all of the following according to the service manual
Drain hose position
Water supply on and clean screens.  Good flow into a bucket when unhooked
Pressure hose clean, clear and tight
Manual Diagnostics
All valves engaged
Spin cycle functioned
Agitate Cycles all worked
Water valve tested off with the meter
Tech sheet show 790-840 ohms
The meter show 1300-1320 ohms
So I order new water valve and installed, still throws the LF code.
New valve shows 1300-1320 ohms
Are the numbers correct on the tech sheet or is the brand new valve bad.  Ordered OEM part from Partselect.
Anyone have this part in inventory to check the ohms on this part #W10342320
Any help appreciated
