kitchenaid dishwasher stops in cycle
  • This topic is locked This topic is locked
7 replies to this topic
#1 Guest_gman_*
Guest_gman_*
  • Lurking at the Threshold
Posted 10 May 2005 - 05:22 PM
my kichenaid dishwasher which is 3 yrs old is now stopping mid cycle.It sounds like a solenoid is kicking in then just stops again. It flashes the light over normal wash with fast then slow flashes. I don't know if this is an erroe code or what? any ideas? thanks gman
#2 Pegi
Pegi
  • 13,120 posts
Posted 10 May 2005 - 05:25 PM
Model Number..........:bathead:
#3 gman
gman
  • 2 posts
Posted 10 May 2005 - 05:32 PM
sorry about that it's a kud101tjbl0:D
#4 Pegi
Pegi
  • 13,120 posts
Posted 10 May 2005 - 05:45 PM
[align=left]Not sure if this is for your exact model, but sure describes your problem. Call Whirlpool tomorrow with your model and serial numbers and see if this is correct for your dishwasher.  Pegi[/align]
[align=left]THIS SERVICE POINTER APPLIES TO THE FOLLOWING BRANDS:[/align]
[align=left]DISHWASHERS WITH ELECTRONIC[/align]
[align=left]CONTROL[/align]
[align=left]Models: KUD01, DU640XT, DUL300XT, GU1100XT, GU1200XT, GU1500XT, GU2300XT[/align]
[align=left]Serial Code Range: FK28 – FM04[/align]
[align=left]STOPS IN MID-CYCLE, INDICATOR LIGHTS BLINKING[/align]
[align=left]Dishwasher will stop in mid-cycle and will not advance.[/align]
[align=left]One or more of the cycle, option and status indicator lights[/align]
[align=left]will blink.[/align]
[align=left]K8178151[/align]
[align=left]January 2002
[/align]
[align=left]CONDITION:[/align]
[align=left]CAUSE:[/align]
[align=left]RESOLUTION:[/align]
[align=left]The electronic control is reacting to higher than normal[/align]
[align=left]line voltage, (over 125 volts), and higher than normal line[/align]
[align=left]signal distortion that exists in some parts of the country.[/align]
[align=left]A revised electronic control, part #8530909, is available[/align]
[align=left]to better handle high voltage conditions. The current stock[/align]
[align=left]of replacement electronic controls has been reworked, to[/align]
[align=left]supplement production controls being produced. Modified[/align]
[align=left]controls will have a label, “REWORKED HI-LINE” to[/align]
[align=left]identify them as reworked controls and are approved as[/align]
[align=left]service replacements.[/align]
[align=left]NOTE:
If the line voltage is normal and a single Cycle,[/align]
[align=left]Option or Rinse Only light is blinking, the cause is usually[/align]
[align=left]a stuck or shorted keypad on the active overlay, not the[/align]
[align=left]control. A resistance check of the active overlay should[/align]
[align=left]always be made, using the keypad matrix in the product[/align]
[align=left]tech sheet, prior to replacing the electronic control.[/align]
[align=left]
 [/align]
#5 gman
gman
  • 2 posts
Posted 10 May 2005 - 05:50 PM
I'll try that !! thank you, I'll let you know how I make out.:D
#6 Pegi
Pegi
  • 13,120 posts
Posted 10 May 2005 - 05:54 PM
Very welcome...... :)
#7 Guest_tried it once; but wasn't sure I was doi_*
Posted 12 May 2005 - 04:35 PM
How do I do  "A resistance check of the active overlay "?
  • 24,323 posts
Posted 12 May 2005 - 05:03 PM
You'd use your ohm meter and the wiring diagram to check the resistance of each and every little led in the matrix.
