GE dishwasher gsd5560g00ss repair help WD26X10013
GE dishwasher gsd5560g00ss WD26X10013
11 replies to this topic
#1 RickSea67
RickSea67
  • 6 posts
  • Flavorite Brew:Flat Tire
Posted 13 September 2014 - 05:43 PM
I ordered the motor/pump kit, everything fits like all the vids and diagrtams say it should, except for the new selinoied elecrtical lines. Easy enough if it were replace black wire with black, white with white, etc. However, I have five wires and no diagrams or vids cover this retrofit. If you know the kit, it comes with all the parts and connectors needed, pic #1, and pic#2 is what I need to change. I appriciate any help with this electrical change. Thank you.
Sorry, can't figure how to attach pics......
#2 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 800 posts
  • Flavorite Brew:orange juice
Posted 13 September 2014 - 06:10 PM
I'm not sure what you are saying, pictures would be good.  The new kit has a solonoid with two wires going to it, the old one should have also had two wires going to it.  I don't know what you mean by 5 wires?  It should be an easy change out.  Atatch pictures via a link to an outside cash, like photo bucket.
Doc
#3 RickSea67
RickSea67
  • 6 posts
Posted 13 September 2014 - 06:30 PM
https://www.dropbox....174637.jpg?dl=0
you may have to cut and paste into your browser
#4 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 800 posts
Posted 13 September 2014 - 06:55 PM
I don't know what that is but it doesn't look like it comes with the pump and motor and solanoid in this kit.Part number: AP2616850
Maybe you got the wrong part for your dishwasher?
Doc
#5 RickSea67
RickSea67
  • 6 posts
Posted 13 September 2014 - 07:10 PM
It's not a  part I ordered, it's what the solanoid has to convert to....
#6 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 800 posts
Posted 13 September 2014 - 07:20 PM
Well the one I posted is the one you should have ordered and well I can't help you cause I never had to convert one.  I'm not sure it will work because the timer on the one with the solanoid, turns on the motor and opens the drain solanoid so the water can exit.  The one with the pump doesn't engage the moter, it just lets the motor rest and engages the pump.  I don't believe wihat you are trying to do will work.  I could be wrong, maybe someone else can help you who has experience with this.
All I can say is why are you trying to change the design of your dishwasher?  Why not go with what it had, that is, replace with the same system?
Doc
#7 Gnominator77
Gnominator77
    IkkĊ-ikki
  • 54 posts
  • Flavorite Brew:Molson Canadian
Posted 13 September 2014 - 07:52 PM
That part in the picture is the turbidity sensor... and should go back where it was on the old pump and motor without removing the wires. The third picture you posted is wiring harnesses that come with the new pump and motor to convert to any configuration.
#8 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 800 posts
Posted 13 September 2014 - 08:09 PM
Thanks for clearing that up Gnominatior.  It makes sense, I couldn't figure out what he was talking about.  Thanks
Doc
#9 RickSea67
RickSea67
  • 6 posts
Posted Today, 03:09 AM
So, my original set up doesn't have a solenoid? Because there are no other plugs except power and turbidity. If this is true, how/where am I creating the power to the solenoid?
And I would of between very happy to have ordered the exact same thingi I had, but GE has been, for some time now, replacing all of the motor/pump kits with the one I received to include the solenoid. Thanks for the feedback guys.
Rick
#10 Budget Appliance Repair
  • 4,754 posts
Posted Today, 06:33 AM
Ignore the drain solenoid, doesn't need any electrical connections.  Yours doesn't use the main wash pump/motor to drain, it has a separate pump just for drain.
William Burk (Willie)
Eureka, CA 95501
#11 RickSea67
RickSea67
  • 6 posts
Posted Today, 02:07 PM
Thank you, I'm not feeling so crazy now. So, I've installed the pump and motor, left everything else connected as was, and nothing connects to the solenoid.
After plugging and hooking everything back up I went to run a cycle, it took a while for it to complete "sensing". While going through the wash cycle water was not coming in, nor was it pumping out. (I poured some water in the bottom just to see if it would pump out) The heater worked, I could hear air being pushed through the drain hose. The original problem was it just wasn't draining. Why would the water flow stop? This is such an easy fix job....
Thank you for the feedback and advice.
Rick
#12 RickSea67
RickSea67
  • 6 posts
Posted Today, 02:11 PM
Sorry, forgot to ask, so maybe replacing the drain pump would fix original problem?
Rick
1 members, 0 guests, 0 anonymous users
