kenmore washer 110.26902691 clicks as it agitates in slow and medium speed but seems to do ok in fast mode,
kenmore washer washer clicks washer makes noise in agitate
11 replies to this topic
#1 damit1
damit1
  • 11 posts
  • Flavorite Brew:any
Posted 22 September 2014 - 05:00 PM
kenmore washer 110.26902691 clicks as it agitates in slow and medium speeds and clicks to the speed of the agitator each direction but seems to do ok in fast mode...
    Shōgun
  • Master Samurai Tech
  • 29,255 posts
Posted 22 September 2014 - 06:50 PM
Remove the agitator and see if the noise goes away.  If it does, then replace the agitator dogs Part number: 80040
Part number: 80040
Check the drive coupler, must remove the case and motor to do this properly Part number: 285753A
#3 damit1
damit1
  • 11 posts
Posted 25 September 2014 - 12:59 PM
Thanks, It is within the motor area, not the agitator. I found a youtube that showed the malfunction but no answer as to what it was. It goes Click Click down in the motor area when the setting is on slow abd medium agitate thanks
#4 fairbank56
fairbank56
    Senpai
  • PipPipPipPip
  • 932 posts
Posted 25 September 2014 - 01:29 PM
  If it's not doing it in high speed agitation or in spin modes, then sounds like a faulty speed select switch.
Eric
Part number: AP3097818
#5 vee8power
vee8power
    Kohai
  • Chief Appliantologist
  • 376 posts
  • Flavorite Brew:Folgers
Posted 25 September 2014 - 03:30 PM
Check the motor shaft for side to side play
#6 damit1
damit1
  • 11 posts
Posted 29 September 2014 - 11:01 AM
I will check those things thanks a lot!! Much appreciated :-)
#7 Maytag1
Maytag1
    Yamabushi
  • 66 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted 29 September 2014 - 07:55 PM
If you have lost low or med speed on your motor than you can have motor pulsing. Motor starts on High speed and then cintrif switch throughs out to which ever speed is selected, if low or med is dead or open, motor will slow until cintrif switch resets at which time it again will start on high and the process starts all over again
#8 damit1
damit1
  • 11 posts
Posted Today, 02:12 AM
So if either the slow or Med are out, it will go through the speeds until it reaches the selected speed (in this case low or medium) when set on either low or medium, and that is why it is surging and clicking in those speeds?? This would make sense as it does fine on high. So looks like a bad motor in that case... I will try the connections and check for burning at the plugs before replacing the motor!! Thank you!!! Great insight and obvious experience!! Brad.
#9 Budget Appliance Repair
  • 4,770 posts
Posted Today, 06:18 AM
It's not very common for the motors to fail in this manner, if you have a speed control selector switch I would look there first, (timer and speed selector switch problems are much more common).
William Burk (Willie)
Eureka, CA 95501
#10 fairbank56
fairbank56
    Senpai
  • PipPipPipPip
  • 932 posts
Posted Today, 11:27 AM
  Agree with Willie. On this model, the motor switch does not select motor speed, it just redirects power back up to the timer after the motor starts. From the timer, power goes to the speed select switch and then to the motor winding based on speed selected by the user. I don't ever recall seeing or hearing of a Whirlpool direct drive machine with a bad motor winding. Not that it couldn't happen, but would be extremely rare and your saying it does it in medium and slow so two bad windings??? Timer doesn't select speed on this model either, except for drain which is high speed direct (bypasses speed switch), so if it's working fine in high speed and you switch it to medium or slow and it starts cutting on/off, then it's most likely the speed switch.
Eric
Edited by fairbank56, Today, 11:30 AM.
#11 Maytag1
Maytag1
    Yamabushi
  • 66 posts
Posted Today, 01:19 PM
The 3 speed motors are famous for this
#12 Maytag1
Maytag1
    Yamabushi
  • 66 posts
Posted Today, 01:24 PM
Easy enough to find out. Just ohm the windings. Have found wires broken between the motor switch plug and the windings. Have seen this also on the Amana 3 speed motors. Usually when the speed selection switch fails, it sends power to two windings at the same time causing high amp draw and cutting off on the motor overload, but not causing a pulsing of the motor
3 user(s) are reading this topic
1 members, 2 guests, 0 anonymous users
