Kenmore washer 110.47511700 He with f-31 eror code
1 reply to this topic
#1 Magenta#90
Magenta#90
    Yamabushi
  • 74 posts
Posted Yesterday, 08:59 PM
I run error code diagnostic, it give me F-31, the I tried to run the other diagnostic test but It doesn't go through. Possible bad MCU and CCU. How to test the MCU, should I disconnect MI3 from the MCU , and try to see if works. Thank you.
#2 applianceman97
applianceman97
    Baby Sensei
  • 1,783 posts
Posted Today, 10:17 AM
The machine will not run without the mcu. the f31 error code points to the MCU. Did you get the tech sheet out of the machine. Your error code is listed there.
