whirlpool range model rf362lxss0 error code F3E2
3 replies to this topic
#1 tars
tars
    Yamabushi
  • 86 posts
Posted 01 October 2014 - 09:48 PM
Range gets too hot and codes out F3E2. tech sheet says check sensor and then erc. replaced sensor, still codes out. Im sure its the erc, problem is that part is a factory order. any one know if its just a stuck relay?
#2 Applianceman97
Applianceman97
    "Hollywood"
  • 2,598 posts
Posted 02 October 2014 - 12:51 AM
What color do you need? black?
    Shōgun
  • Master Samurai Tech
  • 30,720 posts
Posted 02 October 2014 - 10:20 AM
It's not a stuck relay.  Most likely the +5VDC system on the board is borked, at least for the sensor circuit.  Can measure it at the board, where the sensor harness connects.
Should also check sensor resistance from the sensor harness AT THE BOARD to make sure you don't have an open harness somewhere along the way.
Replacement ERC:
Part number: AP3964237
Part number: AP3964246
#4 tars
tars
    Yamabushi
  • 86 posts
Posted 02 October 2014 - 10:54 AM
I need black. I will check the contact when i go back out there today. Thx for the info.
