Frigidaire Refrigerator model # FGHB2844LF4
Ice maker
4 replies to this topic
#1 Nutterman
Nutterman
    Ikkō-ikki
  • Master Appliantologist
  • 34 posts
  • Flavorite Brew:New Castle
Posted 27 October 2014 - 03:58 PM
I've got a Frigidaire Refrigerator FGHB2844LF4 that will not produce ice, i have checked all 3 micro switches on the ice maker, i have tested the mold heater, and the valve. the original call was for the ice maker was leaking into the ice bin. i replaced the water inlet valve then the customer called back saying it had only made 1 batch of ice and nothing after. on the return trip i found that the ice mold had ice cubes in it and they just hadn't been cycled. this has the ice maker in the fresh food section. temps are ok.
#2 BryanS
BryanS
  • 1,206 posts
Posted 27 October 2014 - 05:40 PM
I would never have messed with this icemaker. You are going to need to run the diagnostic and see if it operates correctly. They had one repair kit after another on these things. It was like an icemaker board change as well as a bunch of crap on the icemaker. It's been years since I touched one. I would look for a manual for a model close to this and find the diagnostics.
#3 PDuff
PDuff
  • 2,007 posts
Posted 28 October 2014 - 02:53 PM
Depending on the serial number, you'll be needing one of the upgrade kits or just the icemaker control board.  Kit 5303918495 can be used if there's been no upgrade, and has all of the parts needed (and some not needed).  Your series may only require the board.
#4 vee8power
vee8power
    Kohai
  • Chief Appliantologist
  • 398 posts
  • Flavorite Brew:Folgers
Posted 28 October 2014 - 06:02 PM
Check out these links to other topics about this icemaker:
http://appliantology...r/?hl=nightmare
http://appliantology...are#entry264847
I found these by searching "nightmare".
Durham put together a survival kit for Electrosux fridges:
http://appliantology...r-survival-kit/
It might help too.
#5 clman
clman
    Sōhei
  • Appliantologist
  • 120 posts
  • Flavorite Brew:Abita Amber
Posted Today, 01:02 PM
Good luck on this one. This IM is a pain in the.....
25 Years in the biz. 9 years LG authorized.
