Jen Air Refrigerator JSD2695KGB request service manual
electro_doc
Need service manual.  Problem is refrigerator getting too cold, touch control non responsive.  Need to know how to instigate the test cycle.  Freezer temp is 0 and freezer has frost on back wall, refer is 22-30 degrees and frost on damper.  Never worked on one of these, suspect damper.  Normally would suspect deft problem with frost on freezer back but with deft. problem the temps typically would be higher, not too cold.  Need help!
thanks
Doc
  • electro_doc
I looked before but I'm new at this.  I think I forgot to put the *.   I got nothing when I looked before.  Thanks, I just found it with the *
muchas gracious!
Doc
