KitchenAid KSRG25FVMT00 Ice Dispenser Motor Problem
3 replies to this topic
#1 krbuttsnc
krbuttsnc
  • 2 posts
Posted Yesterday, 04:47 PM
KitchenAid KSRG25FVMT00 side-by-side.  When pressing the ice dispenser lever the auger does not turn.  I removed the ice bin, which was locked solid, cleaned and dried it, but still nothing when pressing the lever.  A also removed the built-up ice in the chute and around the drive bolt.  Suggestions on where to start to diagnose the specific problem?
#2 Maytag1
Maytag1
    Sōhei
  • 124 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted Yesterday, 06:57 PM
First, listen when ice lever is depressed. Do you hear micro switch click? If not, it could be as simple as switch holder being broken:)
#3 krbuttsnc
krbuttsnc
  • 2 posts
Posted Yesterday, 07:07 PM
Well, you might laugh at what I tried, but it seems (hopefully) to have resolved the issue.  The bin and chute were full of ice - one solid block.  After clearing all of that the motor did not work, so I posted the plea for help.  I had a thought that maybe water or ice had traveled down the shaft and had the entire column frozen.  So I used a ratchet to apply pressure in both directions to the shaft.  Nothing seemed to move, but after closing the door and giving the lever a couple of tries it creaked itself back to life.  And now it works!  Is that a common trick to try?
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 4,892 posts
Posted Today, 01:46 AM
Yes, those shafts are prone to freeze up from time to time.
www.DurhamApplianceThrift.com
