Extreme data logging
8 replies to this topic
#1 DurhamAppliance
    Sho' Nuff Chozin
  • 5,248 posts
Posted 09 November 2014 - 11:05 PM
The usefulness of temperature data logging a hard-to-diagnose fridge is unquestionable and has been discussed in numerous threads. However, wouldn't it be cool to also determine when and if the compressor or defrost heater is running or when an evap fan turns off or when the doors are open for an extended period?
This could be done by comparing and analyzing temp info and line current info together.
Using a current /voltage logger along with a data logger may allow this. Supco makes a reasonbly priced current/voltage logger. It's ac only which would reduce some of its usefulness but it still would make a great Christmas gift for the tech who has everything :
http://www.amazon.co...cription-iframe $165
If I can convince my wife to buy one along with all the other toys I want for Christmas, look forward to a Durham's Extreme Data Logging video... but I'm gonna need all of you to help me decipher the data!
Edited by DurhamAppliance, 09 November 2014 - 11:24 PM.
www.DurhamApplianceThrift.com
#2 Applianceman97
Applianceman97
    Baby Sensei
  • 2,187 posts
Posted 10 November 2014 - 11:31 PM
Now that's nifty!
#3 olyteddy
olyteddy
    Kohai
  • 370 posts
  • Flavorite Brew:Earl Grey
Posted 10 November 2014 - 11:54 PM
I had this Lascar Temperature Logger: http://www.amazon.co...1?ie=UTF8&psc=1but our HVAC guy uses it a lot too so I got this Extech: http://www.amazon.com/Extech-Temperature-Humidity-logger-RHT10/dp/B00NG258PQ/ref=sr_1_8?s=industrial&ie=UTF8&qid=1415681455&sr=1-8&keywords=humidity+logger. The Extech measures humidity too so any time the door is open the humidity spikes.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 5,248 posts
Posted 11 November 2014 - 05:22 AM
that's a good point OT. I have two Supcos and one has temp and humidity but I usually turn off the humidity setting since I didn't see the purpose but your idea makes sense.
So then I will data log both fridge and freezer with humidity logging in freezer and also use the current/voltage logger for compressor/fan/heater activity. I would imagine the amp logger would need to be set to record every minute or even every 30 seconds to catch door openings. If this can be done using humidity then the current/voltage logger can then be set to every 2 to 5 minutes.
Just found a very interesting thread from 2012. In it, someone asked about monitoring amps and brother Reg mentioned the amp logger I linked....http://appliantology...ature-problems/
That's what I love about this site, for if you look hard enough, you'll probably find someone has already discussed your problem. Funny thing is I participated in that thread but did not understand the value of amp monitoring at the time.
Also in that thread, I asked about the purpose of humidity monitoring but no one responded..... it's been a long time between question and answer but thanks Brother OT!
Edited by DurhamAppliance, 26 January 2015 - 01:07 PM.
#5 olyteddy
olyteddy
    Kohai
  • 370 posts
Posted 11 November 2014 - 01:18 PM
BTW the reason I got the Lascar was because it cost less on Amazon. ($50 -vs- $75) BUT I bought the second one (the Extech) through Grainger because the prices were reversed...
#6 LI-NY Tech
LI-NY Tech
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 599 posts
  • Flavorite Brew:Virgil's Cream Soda
Posted 26 January 2015 - 12:02 PM
Does anyone know of any Android based dataloggers?  I don't carry a laptop.  It's 2015.
- David
- RD Appliance Service, Corp.
- http://www.rdapplianceservice.com
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 5,248 posts
Posted 26 January 2015 - 12:08 PM
Something I have been interested in for a while. I check from time to time but have yet to find something. I wound up carrying a small outdated, otherwise useless laptop in my truck
#8 LI-NY Tech
LI-NY Tech
    Senpai
  • PipPipPipPip
  • 599 posts
Posted 26 January 2015 - 12:20 PM
This looks possibly useful: http://www.monarchin...oduct.php?ID=60
- David
#9 DurhamAppliance
    Sho' Nuff Chozin
  • 5,248 posts
Posted 26 January 2015 - 12:47 PM
Yeah, I have seen similar devices but from what I gather, the android portion allows for nfc communication which means you have to stand around with your phone to obtain real time logging info. To download from the logging device after your logging period is over, it appears you need to download to a pc.
***update....after more careful study (downloaded the manual) , this product apparently allows all accumulated data to be downloaded to Android device with NfC. (ios eat your heart out... lol) next step... affordability.... checking it out now....... price $49! for temp only and $79 for temp/humidity..... I may take the plunge.... great find Bro L!
Edited by DurhamAppliance, 26 January 2015 - 01:04 PM.
