Kenmore Stove Wont Work (model # 79095652000
3 replies to this topic
#1 cojar
cojar
  • 2 posts
  • Flavorite Brew:Iced Tea
Posted 20 November 2014 - 02:11 PM
Hello
Need help getting my stove up and working so that I can cook Thanksgiving dinner for the kids.
Problem is as follows:
1Stove top and oven do not work
2) Only 5th element (warmer plate) works
3) Clock works only when I turn any control knob for a burner . It blinks 12:00. I can set the clock and and select and set oven temps, but oven does not come on.  When the control knob is turned off again, the clock is not lit and goes off again
Things I have tried:
1) Checked fuse box for tripped fuses
2)Replaced burned wires at terminal (at insulator block on back).
Still doing the same thing.
Thanks in advance for any help you can give me to troubleshoot this issue!
Sonia
#2 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,398 posts
  • Flavorite Brew:What's on tap?
Posted Yesterday, 07:23 AM
Symptoms of a 240VAC range only getting 120VAC. Check your terminal block connections where the cord attaches to the range (again), the plug and the outlet. Use voltage meter to determine where you are loosing power.
Edited by Chat_in_FL, Yesterday, 07:24 AM.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#3 MAPS Appliance Repair
    Ikkō-ikki
  • Appliantologist
  • 57 posts
  • Flavorite Brew:coffee
Posted Yesterday, 08:29 AM
I have seen this in the past,
I  just replaced terminal block and cord.If the wire is burnt at the terminal block, no Question replace both.
Paul
#4 Maytag1
Maytag1
    Sōhei
  • 153 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted Today, 10:44 PM
Sounds like bad power supply to range.
