Whirlpool LER7646EQ0 Dryer - Loud Squealing Noise
4 replies to this topic
#1 Ghost
Ghost
  • Chief Appliantologist
  • 3 posts
Posted Yesterday, 10:47 AM
Most of us immediately think of the idler when a dryer starts squeaking and howling, right?  Maybe the drum rollers as a second.  I have one with a squealing motor.  Of course it was quiet as a mouse once everything was pulled out of the cabinet.  Under side load (as it is when the pulley is tensioned by the belt, the squealing is very loud.
Too bad this noise is coming from the motor.  The bearings are fine.  Inside the motor toward the front of the motor frame you can see a centrifugual cutout mechanism with springs, weights and a switch that rides on a large plastic ring.  After years of operation, the plastic switch arm polishes up the plastic ring and starts squealing.  Adding a little grease to the plastic ring is a waste of time.
This problem is really a waste of an otherwise good motor.  You can actually pull out the connection block and have a good look at the culprits.  Can't think of a clever fix at the moment, but thought I'd make a note of it.  When hunting for a squealing part on these dryers - they are pretty good dryers -  pull the motor pulley hard to one side and rotate it to find this noise.
Unfortunately, the blower fan on an older unit will probably refuse to unscrew, so it is time to chisel off the old one and get a new blower fan too.  But, that's what they pay me the big bucks for, right?
-Ghost
Edited by Ghost, Yesterday, 11:04 AM.
That figures!
#2 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 808 posts
  • Flavorite Brew:Drifter Pale Ale
Posted Yesterday, 01:10 PM
I was working on a coin op machine of this design, had the same problem. Felt like I was chasing my tail once I figured this out... Live a learn
#3 Maytag1
Maytag1
    Sōhei
  • 168 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted Yesterday, 10:04 PM
Instead of a chisel, I use a 1" hole saw. 10 seconds to have blower off:)
#4 Budget Appliance Repair
  • 4,835 posts
Posted Today, 06:26 AM
Medium sized ball-peen hammer and about 5-10 seconds is all it takes to smash the blower wheel off around the center hub area.
William Burk (Willie)
Eureka, CA 95501
    Shōgun
  • Master Samurai Tech
  • 29,648 posts
Posted Today, 08:08 AM
This my preferred method. Elegant, quiet, quick.
