Kenmore refrigerator goes wacka-da-boop!
#1
Posted 11 May 2005 - 01:05 PM
I have a 1989 Kenmore fridge, model # 8790682. Works fine, but whenever (what I suspect is) the compressor cycles off, it makes a sound like WACKA-DA-BOOP, fairly loud.
Am I losing my compressor? Is it the bearings? Or just a loose bolt?
#2
Posted 11 May 2005 - 01:13 PM
Sounds very like a broken spring inside your compressor, but give us that all-important number so we can make a reasoned assessment and give you some ideas on where to look.
#3
Posted 11 May 2005 - 01:24 PM
#4
Posted 11 May 2005 - 01:36 PM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#5
Posted 11 May 2005 - 01:39 PM
Older Whirlpool-build top freezer, simple and robust. There should be a panel at the lower rear which you can remove, see if you can pin down where the noise is coming from.
#6
Posted 11 May 2005 - 02:35 PM
I love the fridge; even the icemaker continues to work flawlessly.
#7
Posted 11 May 2005 - 06:13 PM
#8
Posted 11 May 2005 - 06:22 PM
Thers a lot of expensive equipment used in this kind of job, its exacting and time consuming work, so expect to pay a handsome fee for it.
Bob Sankie
Coastal Appliance, Heating & Air
North County San Diego
www.coastalappliances.com
#9
Posted 11 May 2005 - 09:00 PM
#10
Posted 14 May 2005 - 05:57 AM
#11
Guest_Fridge user_*
Posted 14 May 2005 - 09:04 AM
Save the money for an new one which is more efficicieny.
Your old one could use more than twice amount of electricity.
