>>>KENMORE DISHWASHER NO POWER<<< mod: 665.13742k60
kenmore dishwasher no power main control board touchpad and control panel
6 replies to this topic
#1 santacruzappliance
santacruzappliance
    Ikkō-ikki
  • Appliantologist
  • 30 posts
  • Flavorite Brew:Sculpin IPA
Posted 05 December 2014 - 12:08 AM
I've got a Kenmore d/w mod: 665.665.13742k603 that will not power on.  I have already checked and confirmed:
1)120VAC at outlet and to terminal block under d/w
2) voltage to the main control board
3) both door switchs
5) Door latch functions normal
4) thermal fuse has continuity
This leaves either the touchpad/control panel (p/n: 1551936) at $133.50, or the main control board (p/n: 1874821) at $195.65 as the cause of failure.
My question is: how can I determine which one it is without purchasing both expensive electronic components and simply part swapping?
#2 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,420 posts
  • Flavorite Brew:What's on tap?
Posted 05 December 2014 - 07:18 AM
Remove power
Disconnect  touch-pad ribbon from control
Shut door
Re-apply power
Does drain pump come on?
If so, board is probably good, replace touch-pad...
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#3 santacruzappliance
santacruzappliance
    Ikkō-ikki
  • Appliantologist
  • 30 posts
Posted 05 December 2014 - 12:42 PM
Thanks Havoc!
I did disconnect power,
unplugged ribbon connector from touchpad,
and then plugged back in,
rebooted power and closed door.
No lights, but the drain pump did run for about 20-30 seconds then auto shut off.
Is your diagnostic procedure for this in the service manual or is it one of the tricks I just haven't learned yet?
I just dont see how any tech is supposed to know that unless its in the service manual or tech sheet...
I appreciate the help and knowledge!
Cheers and beers!
#4 Budget Appliance Repair
  • 4,887 posts
Posted 06 December 2014 - 08:21 AM
If this feature is available it will usually be noted on the techsheet, but worth a try even if not.
William Burk (Willie)
Eureka, CA 95501
#5 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 831 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 06 December 2014 - 10:24 AM
IT has been on the tech sheets.  Usually can be found by taking the bottom  cover off and attached to the cover itself.  Common for these touch pads/user interfaces to go bad.  We have changed at least 10 of them in the last year.
#6 santacruzappliance
santacruzappliance
    Ikkō-ikki
  • Appliantologist
  • 30 posts
Posted 06 December 2014 - 04:03 PM
Thanks for the replies.  I will let you guys know what it is after I go out there.
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 5,098 posts
Posted 06 December 2014 - 06:49 PM
Thanks Havoc!
So then why on earth won't you, as a tech, search for or request the tech sheet/manual ??
Pre-diagnosising as mentioned in the video doesn't mean just to come on appliantology and ask how to do something. That's expected from a diyer but not from a professional tech, especially one that is inexperienced and wanting to learn.
We don't mind helping each other with questions but we expect each other to have at least put in some research. Then the discussions between us will be more detailed and fruitful as we will indeed be on the same page. Search the site for prior discussions as well.
Edited by DurhamAppliance, 06 December 2014 - 07:02 PM.
www.DurhamApplianceThrift.com
Also tagged with one or more of these keywords: kenmore, dishwasher, no power, main control board, touchpad and control panel
