KA french door fridge KFXS25RYMS4, or why I hate diode wiring harnesses
8 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 957 posts
  • Flavorite Brew:Guinness Stout
Posted 12 December 2014 - 02:53 AM
To the Dojo,
Customer complaint: little to no ice.
120VAC across the valve, but no drop. I replaced the valve inside fresh food compartment, but still no ice. Per Whirlpool TechLine, I measure 120VAC ABOVE the diode at the single supply water valve at the back. WTH?!!
Anyone else having this problem? What's going on with the diode technology?
Thanks in advance,
Red
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 BryanS
BryanS
  • 1,330 posts
Posted 12 December 2014 - 06:22 AM
I haven't seen any Kitchenaid with diodes for the water valves.
#3 Ghost
Ghost
  • 10 posts
Posted 13 December 2014 - 10:54 AM
Red,
Could you post the section of the diagram showing the valve and diode?
Ghost
That figures!
#4 Spannerwrench
Spannerwrench
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 741 posts
Posted 15 December 2014 - 02:16 PM
That's a first for me, I've never seen a KA with a diode in the harness, but looking at the schematic, it's there.
Attached File  KA Water Valve Diode.png   45.94KB   2 downloads
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#5 Spannerwrench
Spannerwrench
    Senpai
  • PipPipPipPip
  • 741 posts
Posted 15 December 2014 - 05:04 PM
Here's another image to maybe under stand how the diode functions. The diode works by not letting the voltage back flow to the other valve that's not getting activated. It is working kind of like a check valve in this situation.  The voltage goes into the diode to the valve, but unlike a connect, it doesn't allow voltage to flow through to the other connection.  I may not be explaining it properly , but hey, I'm not a teacher either.
Attached File  KA Water Valve Diode.png   58.88KB   2 downloads
"Suds are not good"
#6 Spannerwrench
Spannerwrench
    Senpai
  • PipPipPipPip
  • 741 posts
Posted 18 December 2014 - 04:55 PM
I didn't find it in the downloads section. You probably would have had better luck asking there.
But here it is.
KFXS25RYMS4
W106199610
Edited by Samurai Appliance Repair Man, 19 December 2014 - 10:10 AM.
Added file to downloads
"Suds are not good"
#7 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 957 posts
Posted 24 December 2014 - 09:18 AM
After "nuking that Kitchenaid biotch (a technical Samurai term)," i.e. replacing both valves and wiring harness, customer has fresh water and ice again.
Mr. Tyrus Lee Smith
706-778-3411
#8 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 923 posts
  • Flavorite Brew:orange juice
Posted 24 December 2014 - 09:59 AM
Good job hangin in there!  All's well that ends well.  Every time we make it trough an experience like this one it just makes us better at what we do.  It's why I love this job.  allways something new, never boring.  Keep on movin forward, good job.
thanks for the follow-up, we all help each other learn, it's awesome, thanks again!
Doc
#9 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 957 posts
Posted Today, 12:53 PM
Thanks much
Mr. Tyrus Lee Smith
706-778-3411
