ASKO Dryer- belt stringing (T700)
#1
Posted 11 May 2005 - 02:48 PM
#2
Posted 21 May 2005 - 09:16 AM
#3
Posted 26 May 2005 - 12:06 PM
#4
Posted 26 May 2005 - 03:13 PM
I had the supreme pleasure of replacing my first ASKO dryer belt two days ago. I was reminded why I always say, "ASKO? Oh NO!" After a couple false starts, I ended up replacing the belt as described in your upload-- woulda saved me about half an hour of scratching my posterior and sniffing my fingers if I had seen that before hand. Stringing the belt on the pulley was straight-forward enough but, DAYYAM NATION! getting to it was like going around my elbow to get to my a**hole! I think ASKO engineers must have a special loathing and contempt for repair people.
Bought the belt from RepairClinic for $22... plus $30 for overnight shipping (the customer didn't care about the money, they just wanted the dayyam thing fixed).
Total time took me almost 1.5 hours, including taking down and restacking the laundry unit.
Nice work on your repair and thanks again for the upload!
#5
Posted 01 June 2005 - 06:46 AM
#6
Posted 01 June 2005 - 10:48 AM
PS - Re: the asko instructions - it didn't look like you would have to take the fuse wires off on mine if all that was required was the belt (I slipped it around the front of the drum) - nor would you have to put it face down on the floor, and mine doesn't have a condenser that I am aware of...so the instructions make it sound more complicated that it is (assuming you don't have a broken motor!!).
#7
Posted 01 June 2005 - 04:19 PM
Since I gurarantee all my repairs for one year parts and labor, sounds like I may be going back out on this one on my nickel. :shock:
#8
Posted 15 June 2005 - 12:08 PM
Actually, that is not so much of a manufacturing issue. The shear pin can break off when you put wet and heavy clothing in the drum and the drum flexes too much....attached to the motor by a pin, and that sheared right in half (what kind of manufacturing is that!).
I learned (also the hard way) that clothes going into an ASKO dryer ought to be almost dry to begin with. That means using the high speed spin on the WASHER to wring out the most water possible before putting it into the dryer. The dryer is the biggest energy monster in the whole shebang so you want to run it as little as possible. The washer gets the clothes almost dry anyway.
It was nice of ASKO to back up their product under their warranty. If this was some other manufacturer you would have only had a 1 year warranty or so and you'd be left high and dry for the entire bill.
#9
Posted 15 June 2005 - 12:46 PM
They do have a "stronger" assembly on that pulley arm on the new motor he installed.
Repair costs are high in my area, so I never feel too grateful for anything Asko does, due to the high initial purchase cost and hugh $ invested in repairs and time lost while they are out of service.
#10
Posted 05 August 2005 - 08:52 AM
http://www.repaircli...R=154&N=1154685
#11
Posted 13 October 2005 - 12:41 PM
#12
Posted 16 November 2005 - 07:08 AM
#13
Posted 12 December 2005 - 12:23 PM
#14
Posted 14 December 2005 - 10:47 AM
Been reading the belt saga, and wondering if I start a new topic or stick with this one as I am ran into the same thing. {Under 5 year warranty, pin broke, service people replaced motor {as the pin thingie was attached to the motor} and also had the belt replaced, and I am sitting on a bill for $200, because.....the first run after the repair, we walk into the laundry room to a nasty burnt rubber smell, a little smoke, and the dryer still running, but the drum not turning. As only a week since the service call [ drying outdoors} we called - they said try the reset button, which we did, nada, but the reset button does not do a "click" like the manual says it should. Now the dryer just hums, and the drum won't turn at all. Maybe the tech {who clearly had never seen an ASKO in his life} put the belt on wrong, or wrong part?
I was thinking of repairing ourselves, as 5 warranty now one month over, and the service people have kinda blown us off, saying they won't be here for few months, as they have lost a few of their techs. {This is true I hear from sources..}
Any suggestions? I am clever technically, but never have worked on my own appliances, so in other words, I don't know what the hell I am doing {either!}
Another idea... call Asko USA and scream like hell for them to add a dryer to that free shipment of a replacement ASKO dishwasher, to replace the one that caught on fire last night {another story - still in the making}
"Oh NO! Don't get ASKO!"
Julia
#15
Posted 14 December 2005 - 03:32 PM
In the meantime, use the pdf attachment in this topic to replace the belt yourself. It sounds like it hopped off the pulley and the motor shaft is spinning against it, burning it.
#16
Posted 19 December 2005 - 02:33 PM
I am going for that pdf now on the dryer belt.
{maybe I should go to another thread?} On the Asko model 1385 dishwasher saga {the one that caught on fire during the rinse/drain cycle} - - I talked to Asko, The first line guys [meaning, I'll believe it when I see it} said if I can provide them with an invoice saying the fire started in their machine, they will give me half off a new one. I then relayed that it was "nawt bloody likely" that I would be paying for a new one, when I could buy another more reliable brand for less than the half they would give off. After a few minutes on hold, they then said that they would replace it for free if it was determined that the fire started in the dishwasher {meaning not my installation or electricity} This I think I can prove pretty easily. We shall see what I get.
Then, another repair guy told me make sure that that repair invoice explaining the problem must come from the place that installed it, or the place I bought it from. {Asko certified} or I'll be paying a few service call charges before I see the goods. He is Asko certified, but works as a subcontractor to the sales shop.
Hope this helps,
Julia
#17
Posted 04 January 2006 - 02:14 PM
#18
Posted 10 January 2006 - 09:44 PM
#19
Posted 11 January 2006 - 11:21 AM
Hope it all worked out for you
#20
Posted 25 February 2006 - 09:05 PM
1. I did not have the 3 screws in the lower "semi-circle".
2. The main center bolt on my unit had a plastic coating that needed to be cut off.
3. I didn't unplug anything or disconnect any wires. Simply lifted the belt around the front of the drum.
4. Hint for easier working. I used small pieces of tape to hold the belt in the center of the drum in THREE places. This assisted in getting the tensioner laced with one hand. Be sure to remove the tape before closing. I did all of this while the unit was face down on the front.
5. Before starting the unit back up, try to vacuum and blow out all the lint from the heating element. My unit smelled like burning paper for a few seconds. Some others could be worse.
Thanks again.
This topic is locked
