Frost Free Freezer with Frost -Whirlpool s/n U23003234 Mod EV160NZ1002
10 replies to this topic
#1 onetazdevil
onetazdevil
  • 13 posts
Posted 17 December 2014 - 12:44 PM
Help! I have a  Upright freezer that is stored in my shed outside. It keeps accumulating frost on the lower vents which looks like the main vents. When this happens the things on the top shelf and the door do not get frozen. I keep defrosting it but it keeps happening over and over again. My boyfriend is wondering if it had something to do with the gel ice packs keep in there so I took them out and defrosted. It seemed to work at a normal setting until he put some of them in there again then the frost came and now even on the high setting the top shelf and door are not freezing with the exception of the things already frozen solid
#2 Spannerwrench
Spannerwrench
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 741 posts
Posted 17 December 2014 - 05:05 PM
You could have a defrost problem, but, if it works without the gel packs there then they are causing the problem.  A little bit more information and clarity would help in diagnosis.
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#3 onetazdevil
onetazdevil
  • 13 posts
Posted 17 December 2014 - 07:44 PM
What kind of information do you need to clarify? I have since taken the gel packs out but now I have to get the frost out of there.
    Shōgun
  • Master Samurai Tech
  • 29,841 posts
Posted 18 December 2014 - 09:28 AM
Sounds like the gel packs are somehow interfering with the door and preventing it from sealing all the way. Look for gaps between the door gasket and cabinet with the gel packs inside the compartment.
#5 lvasquez11
lvasquez11
    Sōhei
  • 212 posts
Posted 18 December 2014 - 11:28 PM
All whirlpool upright freezers have defective defrost timers. If manufactured within last year n half.
If you call whirlpool . they will cover part n sometimes also labor
Might be better just replacing Defrost timer Part number: 482493
Part number: 482493
#6 onetazdevil
onetazdevil
  • 13 posts
Posted 19 December 2014 - 11:14 AM
This freezer is 21 months old. I did call Whirlpool and all they offered was to send a tech to my house for a fee. I am low income and cannot afford to have anybody come out :(
#7 lvasquez11
lvasquez11
    Sōhei
  • 212 posts
Posted 24 December 2014 - 09:35 PM
Amana, Maytag and Whirlpool Refrigerators and
Freezers/Defrost Timer Won’t Advance Into a Defrost
or Possibly Won’t Advance Out of a Defrost Cycle
Models:
 Freezers: AQF1613TEW, EV161NZTQ, EV160NZTQ, MQF1656TEW, EV181NZTQ,
EV180NZBQ, EV188NYWQ, EV188NYWS, EL88TRRWQ, EL88TRRWS, EV201NZTQ,
EV200NZTQ, EV200NZBQ, AQF2013TEW, MQF2056TEW, V250NXTQ.
Serial Number Range: U225 - U326
#8 Maytag1
Maytag1
    Kohai
  • 260 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted Yesterday, 08:26 PM
If you turn the knob on your defrost timer clockwise with a flat blade screwdriver slowly until unit cuts off, this manually puts it into defrost. Once in defrost, listen for your heater to be on. You will hear popping and sizzling after in defrost for 5-10 min. If heater does come on, this means that your heater and defrost t-stat are good and you have a bad timer. If your heater doesn't come on, then that means either your heater or defrost t-stat are bad
#9 onetazdevil
onetazdevil
  • 13 posts
Posted Today, 07:32 AM
I contacted Whirlpool again this time on their website. Waiting for a reply. Is the defrost timer inside the t-stat inside freezer or is it behind it in the bottom opening? I see the photo above but cannot play the video because of slow internet
#10 Maytag1
Maytag1
    Kohai
  • 260 posts
Posted Today, 07:39 AM
Usually the timer is on the rear of the freezers. Sometimes behind the kick plate. Heater and defrost t-stat are inside behind rear panel
#11 onetazdevil
onetazdevil
  • 13 posts
Posted Today, 10:47 AM
Thank you
1 members, 0 guests, 0 anonymous users
