Fisher and Paykel DG27CW1
Wont get hot
6 replies to this topic
#1 joeverslype
joeverslype
  • 3 posts
  • Flavorite Brew:MGD
Posted 21 December 2014 - 09:03 PM
Dryer goes through all the motions just fine, but creates very little heat.
    Shōgun
  • Master Samurai Tech
  • 29,844 posts
Posted 22 December 2014 - 10:02 AM
Disconnect the vent from the dryer and run it that way to see if the heat increases. A vent with restricted air flow will cause the heat to short cycle.
#3 joeverslype
joeverslype
  • 3 posts
Posted 22 December 2014 - 01:52 PM
I bought it used and cleared out the vent when I installed the dryer. When I go outside the vent cover flaps are wide open with just barely above room temperature air blowing out like a small jet engine. I was wondering if there is some kind of regulator or thermostat that is a common problem.
#4 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 711 posts
  • Flavorite Brew:yeunling
Posted 22 December 2014 - 02:05 PM
Is this a gas unit? Could be set up for wrong type of gas
#5 joeverslype
joeverslype
  • 3 posts
Posted 22 December 2014 - 03:31 PM
It is a gas unit. It says it was tested for LP and natural gas and set up for natural, which is what I have. It worked fine for a week.
#6 stewartservice
stewartservice
    Sōhei
  • 169 posts
  • Flavorite Brew:Yuengling
Posted 23 December 2014 - 06:09 AM
Max temp on that is 149. Check the lint screen. Remove lint bucket, remove 1 screw behind lint bucket, pull housing out at bottom that lint bucket sits in. Usually loaded there.
#7 cmlewis1272
cmlewis1272
  • 16 posts
  • Flavorite Brew:Crown royal
Posted Today, 10:48 PM
Be very certain your free of any lint blockages. If you are u should check out your cycling thermostat. They do go out. Be sure to check it in conjunction with the heat selection switch if so equiped. Get the tech sheet out and run those test.but the cycler is the best bet baring any other simpler problem. Hope that helps
0 members, 1 guests, 0 anonymous users
