Sub Zero 501F door gasket
No replies to this topic
#1 radji
radji
  • 1 posts
  • Flavorite Brew:Something fruity...
Posted Yesterday, 11:56 PM
Read thru the previous thread here: http://appliantology...o-501r/?p=79882
I had to replace the door gasket on our 501F.  The original had a large gash at the bottom.
Ordered a new one (part number 7010578) from Amazon here: http://www.amazon.co...0?ie=UTF8&psc=1
Put the new one on and it doesn't seal at the top now instead of the bottom.  I can hear a leak at the top and there is no vacuum pull when the door closes.  Not sure if its the door seal now or the door alignment.  I can tell the door is crooked when closed.  The left side sits lower than the right.
Suggestions?
