Maytag intellidry dryer MD7600AWW
26 replies to this topic
#1 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 11 May 2005 - 06:53 PM
sorry model number is MDG7600AWW
in the timed cycle it does not dry all the way.. but timer does turn and heat does come on , but not enough.
in the intellidry cycle it heats up at first then seems to sit forever between more dry and less dry,clothing is luke warm at best and damp
we have damp cloths...lol:shock::(:?
  • 24,347 posts
Posted 12 May 2005 - 03:01 AM
This sounds like a dryer venting problem and it's something we have to eliminate.
Run the dryer on timed dry with the vent completely disconnected.  Air flow should be strong and hot (between 145 and 165F-- check with with a meat thermometer.  If it checks good, you have a venting problem.
#3 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 12 May 2005 - 12:58 PM
ok......doing a load of laundry so I can try it out... in the mean time put clean new exhaust on it all the way out...ran it on timed with no exhaust reached at least 150 degrees.
there may have been a restriction where 2 pieces of duct were shoved together... it was down to about 3" diameter at the restriction.
be back in an hour or so......
thanks
PS should I be drinking beer while doing this?Posted Image
  • 24,347 posts
Posted 12 May 2005 - 02:17 PM
Dryer venting jobs always call for copious quantities of the fermented bubbly.  :guzzle:
#5 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 12 May 2005 - 02:22 PM
lol
ok have fresh load in dryer for 1 1/2 hours on intellidry cycle...hasn't moved at all and clothes are cold and damp?????Posted Image
  • 24,347 posts
Posted 12 May 2005 - 02:23 PM
Do it on timed dryer, no vent connected, high heat.
#7 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 12 May 2005 - 04:44 PM
ok finally advanced once it started to dry in the intellidry cycle. it just doesn't seem to heat up enough in that cycle so the time just sits there untill it does start to dry some,  About 2-3 hours to dry
* did run it on timed, high heat or regular, no exhaust hooked up and it heated to 150 that was with no clothes in it and only for 5 minutes.
* ran brand new clean 4 inch duct all the way outside so its not that
One thing though and this might be important................
.when i ran it with the exhaust disconnected i could hear the heater click on but did not heat up and could smell a little gas....then about one minute later I heard the click again and it did heat up.....is there some sort of igniter that could go bad that would cause all my problems?
also been smelling gas outside near where the exhaust leaves the house...
  • 24,347 posts
Posted 12 May 2005 - 05:06 PM
Did you run the load with the vent disconnected? This is important. Do not attempt to second guess the Master; my thoughts are not your thoughts, my ways are not your ways. Wax on, wax off....
#9 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 12 May 2005 - 05:16 PM
no.... the 3 hour tour was with vent connected
will do next load with vent disconnected on the intellidry cycle:notworthy:
#10 rubbercat
rubbercat
  • 3 posts
Posted 12 May 2005 - 05:22 PM
Had a Maytag .. old one though.. did this same thing.. turned out the blower wheel was bad (spinning loosely on the shaft)..just wasn't moving enough air to keep it from overheating and kicking the overlimit out.. but was moving enough air to turn it off and on.. therefore warm up a small amount  and would "dry" clothes if one waited long enough...did NOT make the characteristic rattle on start up and shut down.. may have at one time... dunno.. it was a "gift" was not operating properly when received.  Follow  Samauri's advice venting advice and make certain that airflow is STRONG... ie blowing forcefully !!
Mine was blowing but not having experience with said machine I had no idea just how wimpy it was while broken until it was repaired.
  • 24,347 posts
Posted 12 May 2005 - 05:27 PM
That is not the test I specified. Scroll up and re-read it.
#12 Samurai Appliance Repair Man
  • 24,347 posts
Posted 12 May 2005 - 05:28 PM
Here, I'll make it easy for you:
#13 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 12 May 2005 - 05:36 PM
Hey Rubbercat...thanks for the reply.....the air flow coming out the back of the dryer is very strong,
will run load after work tomorrow....if I make it to work that is.........with all the beerdrinking I have to do troubleshooting my dryer.
got it
#14 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 13 May 2005 - 01:51 PM
ok drying load    timed dry-vent unhooked-hi heat.........................
#15 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 13 May 2005 - 02:45 PM
cycle finished on time....did not dry
#16 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 13 May 2005 - 04:15 PM
next load I cleaned the sensor in the dryer drum(2 metal bars) with some very fine sand paper and ran load on intellidry.....no luck ....dial sits in one spot until it starts to dry some(well over an hour), then moves as it dries with luke warm temps...
#17 Guest_Gas Unit_*
Guest_Gas Unit_*
  • Lurking at the Threshold
Posted 14 May 2005 - 04:29 AM
It is a gas dryer.
Check for bad (or open-circuit) temperature sensor.
#18 Pegi
Pegi
  • 13,120 posts
Posted 14 May 2005 - 05:08 AM
Gas dryer....hummmm.....would also suspect weak coils on the gas valve....seen this gobs of times over the years.............
#19 Moostafa
Moostafa
    Senpai
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 14 May 2005 - 06:19 AM
Hello, my unheated friend.  I was perusing the content-rich website of our most-glorious host, Samurai Appliance Repair Man, while ruminating on your dryer dilemma and stumbled upon this excellent page on gas dryer burner operation.  I believe you will find it to be manna from appliance repair heaven.
Allahu Akbar!
#20 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 14 May 2005 - 07:11 PM
OK,, bought multi-tester......I'm goin in:ninja:
Moostaffa thanks for the great link
Gas Unit I'm Going to check out that temperature sensor
Pegi will the resistancer numbers on moostaff's link be good
for these maytag coils?
[user=1]Samurai Appliance Repair Man[/user] I ran it on both that way and it comes up to temp 150+
but heat does not stay on and does not dry clothes in a normal manner. pretty much all cool air with little spurts of heat few and far between
