Maytag intellidry dryer MD7600AWW
26 replies to this topic
#21 Pegi
Pegi
  • 13,120 posts
Posted 14 May 2005 - 07:53 PM
Something is causing your gas valve to close when it should be open.  Coils that are going out will cause this problem and could also cause the gas smell since weak coils can cause the valve to not open or close properly,  I would start with replacing the coils first if it were my dryer.
#22 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 14 May 2005 - 07:59 PM
should i bother trying to check them?
#23 grahambo
grahambo
  • 1 posts
Posted 17 May 2005 - 08:04 AM
I was having a similar issue, where it was taking 3 hours to dry a load, with model number MDG7057AWW, and had already replaced one of the thermostats to no affect. Then I came across this forum, and saw this discussion.
I tried drying with the vent disconnected, and the dryer still took too ong, so yesterday I replaced the coils, which did the trick.
My thanks to Pegi, Moostafa, and Samurai for the information about the coils.
#24 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 17 May 2005 - 11:55 AM
Cool.... ordered both coils yesterday, sounds like the same problem.
#25 Ralphw
Ralphw
    Ikkō-ikki
  • 28 posts
Posted 19 May 2005 - 12:36 PM
Thanks Pegi,,,,thanks everybody
Got coils-5 minute job-dryer works like new:D
awesome website guys
#26 Pegi
Pegi
  • 13,120 posts
Posted 19 May 2005 - 01:33 PM
Thank you very much for letting us know, makes the time we spend helping in here worth while!!   :cool:
#27 Guest_scouncil1_*
Guest_scouncil1_*
  • Lurking at the Threshold
Posted 19 December 2005 - 03:30 PM
Having the identical problem as Ralph.  Ordered 2 new coils.  Will let you know how things go.  After studying the problem for hours....the problem with my Maytag dryer MDG7600AWW is that the gas valve is not opening consistently.
