Maytag Epic Z MHWZ600PW02
5 replies to this topic
#1 LI-NY Tech
LI-NY Tech
    We Fix Shit Great!
  • Master Appliantologist
  • PipPipPipPip
  • 992 posts
  • Flavorite Brew:Six Point Brewey Hi-Res IPA
Posted 16 January 2015 - 03:50 PM
Maytag Epic Z MHWZ600PW02 washer.  Got a call yesterday for this washer - not spinning.  I found an F25 error and was able to find a loose connection on the motor plug.  Reseated it and it worked great.  Today she calls back with an F21 - long drain error.  Seems like an unrelated code.  I go back Monday for this, any chance this F21 is related to the F25?
David
RD Appliance Service, Corp.
PO Box 234, Bethpage, NY, 11714
516-561-0523
http://www.rdapplianceservice.com
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,949 posts
  • Flavorite Brew:Killians Red
Posted 16 January 2015 - 04:33 PM
Gut sez no...but based on the week I just had , I'm not sure I'd take my advice about anything.
#3 certified tech group 51
  • 2,704 posts
Posted 16 January 2015 - 06:17 PM
Was the F -25 code the only code displayed and in storage???..........Have seen front load units with a slow drain, start to spin but was not balanced ...But balanced enough to bang around to pull wires loose or in the case of the older friggys', pull  the brown wire loose at the motor connector......So it is possible the slow drain is the culprit........After you reconnected the loose connection, you tested it and it worked fine, that's cuz it was already empty...... Fill and watch the water level drain during the drain cycle......................You may need to do some tap dancing to get some dough, kinda like its related but not really..... :bunny:  .
#4 LI-NY Tech
LI-NY Tech
    We Fix Shit Great!
  • PipPipPipPip
  • 992 posts
Posted 16 January 2015 - 06:20 PM
F25 was the only code stored. After reseating the connector I ran 3 diagnostic cycles and they all drained ok. So I'm thinking it's probably unrelated.
Edited by LI-NY Tech, 16 January 2015 - 06:33 PM.
David
516-561-0523
#5 Maytag1
Maytag1
    Kohai
  • 373 posts
  • Flavorite Brew:Bud Lite & Landshark
Posted 16 January 2015 - 09:30 PM
Think unrelated. Bring a pump with you
#6 LI-NY Tech
LI-NY Tech
    We Fix Shit Great!
  • PipPipPipPip
  • 992 posts
Posted 19 January 2015 - 01:40 PM
Update. Aside from the stored F21 I saw indication of a pump or draining problem. Drained great multiple times. I found a couple of coins in the trap, but that's it. I cleaned the trap and reran the diagnostic test, which compled without incident.
David
516-561-0523
