Kitchenaid built-in oven door adjustment
4 replies to this topic
#1 davec
davec
  • 3 posts
Posted 11 May 2005 - 10:33 PM
I have Kitchenaid built in oven Model  KEBS107dSS10.  Someone(no names, please) let the the door drop and now the door is out of alignment.  Any suggestions on how to adjust it?
  • 24,698 posts
Posted 12 May 2005 - 03:46 AM
DOH!  I hate when that happens.
Sounds like you bent one of the hinges.  You're better off just replacing both as a set.
#3 ktsenya2
ktsenya2
  • Master Appliantologist
  • 16 posts
Posted 12 May 2005 - 07:34 PM
It sounds as though the door hinges are now pranged (?) and most likely will need to be replaced if they cannot be straightened out. Either way, the door will have to come off in order to facilitate ant further diagnosis.
Bob Sankie
Coastal Appliance, Heating & Air
Serving San Diego’s North County
www.coastalappliances.com
#4 davec
davec
  • 3 posts
Posted 13 May 2005 - 12:27 PM
Thanks, I will check the hinges.  There is also a pair of hinge receivers on the oven.  Is there any adjustment on the placement of these receivers?  It looks like one of them may have shifted slightly, but I don't want take it apart if there is no adjustment.
#5 Moostafa
Moostafa
    Senpai
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 14 May 2005 - 06:30 AM
Hello, my unhinged friend.  The only adjustment for these hinges is for tension, not position; once they are bent, they are ruined and must be cast into the fire which is never quenched.  I am afraid that your only recourse at this point is to replace the hinges.
Allahu Akbar!
